Old 10-09-2019, 11:04 AM   #1
top replacement
would a soft top from an 04 fit on a 00? Talking the whole top assembly. Might have a deal on one if I can get the price right.
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 10-09-2019, 01:12 PM   #2
1999 base
Meir's Avatar
it can be retrofitted.
i think there is an article about it on the pelican website.
you will need some other components then just the top itself.
Old 10-09-2019, 02:50 PM   #3
SC-986's Avatar
The ‘03-‘04 top and frame assembly’s will fit any 986 series Boxster.
I just replaced the vinyl window top on my ‘02 base with ‘03 glass top and frame assy.
Pretty easy procedure. Here is a tutorial I used.
https://www.planet-9.com/attachments/987-cayman-and-boxster-problems-and-complaints/80066d1458156231-987-boxster-hood-removal-help-boxsterconvtopconversionpartiformatt-pdf
2002 Boxster base - Seal Grey, 5spd trans.,ROW M030 upgrade, FVD Brombacher software tune
2004 550 Spyder Anniversary Edition, #1541,Tip, TechnoFix DOF IMSB upgrade
SC-986 is offline   Reply With Quote
Old 10-09-2019, 03:50 PM   #4
Thanks for the link. Going to read through it all tonight. What I am looking to do is just replace the entire top, including all the hardware and parts necessary to swap over. I couldn't find anything on Pelican's site other then just a how to on replacing the top itself. With some cars it's as easy as just unbolting a few things and putting back on.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 10-09-2019, 04:53 PM   #5
SC-986's Avatar
One of the easiest upgrades I’ve completed. Only (3) bolts to remove on each side. Took me (3) hrs. to remove original top and frame and then install and adjust the ‘03 top and frame. Good luck.
Old 10-09-2019, 05:30 PM   #6
Just found a video on youtube. Very easy to do. Thanks all!
Video: https://www.youtube.com/watch?v=mkTLoHlhGPY
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 10-09-2019, 05:32 PM   #7
KevinH1990's Avatar
It is a great upgrade on a base 2000. You add the glass rear window with a defroster and a headliner. It gives the car a more upscale feel. If you can get a good deal on the top and frame I recommend that you accept it. You may need a second person to help you in order to avoid scratching your paint.
KevinH1990 is offline   Reply With Quote
Old 10-09-2019, 08:30 PM   #8
When your getting ready to lift old top or install new top, tilt assembly forward just a smidge...
Old 10-11-2019, 07:44 AM   #9
Porsche "Purist"
Paul's Avatar
Be careful not to tear the foam drain trays. Very easy to stab them.
1987 924S. 2002 996TT. PST-2
Old 10-12-2019, 09:48 AM   #10
This is an impossible swap. Do not try!
And please send me contact info for the 04 top...
