Old 05-29-2019, 05:08 AM   #1
Rear axle support for jacking up
Do people use it to jack up the whole rear end? I used to use the mounts on the diagonal braces but mechanic told me that was a no, no. Considering he was the head guy at a dealership for years, he must know something. Funny, 101 says to use those and then a video I watched last night on utube on jacking a 986 showed the same thing. I'm so confused.
Anyways, I bought a new jack and am eager to jack something. Please advise.
DWBOX2000 is offline   Reply With Quote
Old 05-29-2019, 06:33 AM   #2
You could jack the car from its normal jack points if you need a quick hit.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
Old 05-29-2019, 06:51 AM   #3
I jack the rear up by the end of one of the diagonal chassis supports.
Old 05-29-2019, 07:05 AM   #4
Yeah, I have done the diagonals as well with out a problem. I was just told not to which got me concerned.
I use the jack points but sometimes I want to put stands where the jack points are which causes an issue.
Bentley showed the rear axle support which is dead center. Anyone else use this point.
I'll ask my mechanic again, maybe I misunderstood him.
Old 05-29-2019, 08:28 AM   #5
they do permit the center support in the manual, but I don't care for that. That aluminum brace seems a bit flimsy
Old 05-29-2019, 12:09 PM   #6
jaykay's Avatar
I put a hockey on my low profile jack and raise the corner via the LCA. Then I place a jack stand under the factory jacking point and lower onto it.
Just my way as I know for sure the LCA will take the load and fairly accessible on a lowered car. A centre point is pretty hard to reach when lowered
986 00S
Old 05-29-2019, 02:14 PM   #7
steved0x's Avatar
YEah and it's hard to get too without a long jack. The one time I did it I bent some of the sheet metal brace around that end. I always use the chassis diagonal as shown in the 101projects book.
Old 05-29-2019, 03:06 PM   #8
The Radium King's Avatar
i think the term is 'subframe assembly". it's the big bit that connects the chassis, control arms, diagonals, and the aluminum brace. regardless of which one (left or right) you lift from, the car is rigid enough that the whole back end will come up. then, since you are not using the rear jack points, you can get a jack stand under them to keep things secure.
Old 05-29-2019, 06:34 PM   #9
On the slippery slope
JayG's Avatar
I just ask my Uncle Martin to levatate it
2004 996 Targa Tip
Instructor - San Diego region
Old 05-30-2019, 12:00 AM   #10
I use a jack point at the rear cross piece for raising the full rear end. I then usually put jack stands under the jack points at the bolt area of the cross braces. Never been an issue at all. I also use the jack points depending on what I need to do. Centerally raising the entire rear end makes life fast and easy when raising the car.
Old 05-30-2019, 06:35 AM   #11
2003 S, Arctic Silver, M6
paulofto's Avatar
Geez, now that is a reference you don't hear much these days. Mid sixties My Favourite Martian.
Old 05-30-2019, 05:43 PM   #12
Artist, 986S tinkerer
NewArt's Avatar
I have raised my car many many times using the suspension structure at the rear of the diagonal brace. Then you can slip in the jack stands at the regular jack points.
Old 05-30-2019, 06:06 PM   #13
Thanks guys. Seems like the sub frame assembly is okay.
Old 05-31-2019, 05:28 AM   #14
Tailwind's Avatar
With a low profile jack (or wheels up on 2x4's), the jack can be placed between the front bolts that hold the plate to the subframe cross-member. This facilitates putting the jack stands under the rear lift points.
'99 986 Base
2010 Golf TDI
'74 914 2.0
'56 356A
Tailwind is offline   Reply With Quote
Old 05-31-2019, 06:31 AM   #15
Need For Speed
KRAM36's Avatar
Put a very thick book between the jack and the car to keep from damaging plate or bolts while jacking up the car, put jack stands in place and get the job done.
Also don't forget to chock the front wheels.
2003 Boxster S
Old 03-07-2021, 08:59 PM   #16
Guys, is it fair to say that either of these locations is fine (circled red + yellow), with a preference for the more forward subframe/crossmember area (circled yellow) highlighted by @Tailwind (and which I believe the Bentley manual suggests as well)?
2007 Boxster 2.7 5MT
2006 325i 6MT
losblancos is offline   Reply With Quote
Old 03-08-2021, 12:19 AM   #17
A8ked's Avatar
Yes, the yellow area is the best for balance, but the red spots will also work just fine.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
Old 03-08-2021, 07:22 AM   #18
1997 Tip, 2018 Macan
rexcramer's Avatar
+1, I always use a hockey puck between the car parts and the jack for protection.
