I use a jack point at the rear cross piece for raising the full rear end. I then usually put jack stands under the jack points at the bolt area of the cross braces. Never been an issue at all. I also use the jack points depending on what I need to do. Centerally raising the entire rear end makes life fast and easy when raising the car.
