05-07-2019, 12:49 PM
Stripped Brake Caliper Bolt Hub Threads
Ohhh Noooo! I was in the process of changing my brakes (pads and rotors) and found that the upper caliper bolt on the front right wouldn't torque properly (it would tighten and then turn more, tighten and turn more, etc). Damn, I knew this wasn't good.
Removed the caliper and found that the threads inside the hub were stripped. My first thought was "who worked on this last?". Uh. It was me.
Two choices - I could replace the hub or try to repair the threads. I tried using a thread tap but they were already too far gone to be chased properly so I ordered a kit called Time-Sert in the proper size. The kit was kind of expensive ($96) but it was still cheaper than replacing the hub.
Amazon Time-Sert M12x1.5
The kit came with everything you need and five inserts. It was easy to use with very clear instructions. Here is the repair process:
Drill out the hole. The drill and countersink bits in the kit were too big for the chuck on my drill so I used a 3/8" socket bit in the drill and a socket to fit onto the end of the drill shank.
Drill out a counter sink....
Tap the new threads. I used a ratchet and socket to carefully run the tap into the hub by hand.
05-07-2019, 12:53 PM
Screw in the insert and you're back in business!
I also ordered new caliper bolts. The new bolts came with a star pattern rather than the old hex pattern. Good thing that I already have a full set of star sockets!
The caliper bolt torqued up properly and here it is, all done! Took me about 30 mins. I took my time and tried not to screw it up (really wanted to avoid the time to replace the hub!).
Ready for pads!
05-07-2019, 12:55 PM
Nicely done!
You might have a candidate for a rent-a-tool.
1989 928 S4 5 spd - black
05-07-2019, 02:39 PM
98 Arctic silver 986
I had a caliper bolt break of in the hub a few years back. Took it to my indy, he couldn't get it out either. I ended up getting a hub from Woody.
05-07-2019, 03:00 PM
1998 Boxster Silver/Red
Great job!!!!!
Everytime I pick up a new tool, the last one being the power bleeder, I tell her it will pay for itself the moment it touches the car.
+1 on the rent-a-tool. With reasonable to/from postage it'll pay for itself many times over.
Cheers!
1998 Porsche Boxster
05-07-2019, 03:03 PM
Time-serts work very well, many went into the Shelby Series 1 frames in 1999.
05-07-2019, 04:08 PM
We use them at my dealership all the time on blown out spark plugs. Saves the customer a ton of money. But you have to install them right, or they can also spell doom.
05-07-2019, 04:19 PM
For us racers that change the rotors frequently, I can highly recommend getting a stud kit:
Brake Caliper Stud Kit - Cup Car Style-Rennline, Inc.
If you have a contact at the dealership you can buy the PMNA cup car parts instead for a little cheaper.
05-07-2019, 04:52 PM
Yeah I've got the Tarett studs, makes it sooooo much easier when taking the caliper off.
05-08-2019, 07:26 AM
Plus 1 on the Tarett studs. Really great quality kit.
Van
05-11-2019, 03:17 PM
Porsche specifies these screws be replaced, not reused every time they're removed.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
05-12-2019, 03:00 PM
Pretty much every car manufacturer today recommends replacement, not just Porsche.
If they are one time stretch fasteners, then yes it makes sense, well, except for being stretch fasteners to begin with. Otherwise, it's definitely a belts & suspenders approach b/c the stresses on them are more compressive than tensile... well, except on my F150 which specified 150 lb ft. of torque along w/ loctite blue - LOL.
"Cool Prius!" - Nobody
05-13-2019, 04:14 PM
Galvanic corrosion. Steel bolts in Aluminum. That's what we're dealing with. If you can limit contact with oxygen you can prevent it. I've had good luck with anti-seize, and others like to use oil-based paint. Many people swear by Tef-Gel. I've never tried it, but it's made specifically for applications like this.
