Old 01-12-2015, 01:38 PM   #1
Apple Carplay in the Boxster?
Hi,
Has anyone installed the hardware and enabled carplay in their 986's yet? Has anyone even debated it and figured out the pros/cons etc?
Should be like installing any other double din receiver I suppose. I use an iphone and I think this would be a pretty nice upgrade in my opinion!!
Installing Apple CarPlay and Taking It For a Spin - Consumer Reports News
Cheers,
Amit
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 01-13-2015, 06:53 AM   #2
BruceH's Avatar
I did this instead:
Ipad mini in-dash installation
Works great and I highly recommend it! With that said, I am looking for a CarPlay receiver for my truck. So far I have only seen Alpine and Pioneer models which have not impressed me. Still waiting.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 01-13-2015, 07:42 AM   #3
Very nice! I really like the iPad mini installation and functionality much better, but it also means that I will require to buy an iPad with GSM/LTE and also add another data plan to be able to use navigation. With carplay, you can use the Apple Maps app and use your existing data plan for your phone.
I did this instead:
Old 01-13-2015, 01:31 PM   #4
BruceH's Avatar
You can always use your phone as a hot spot. I bought a used iPad mini which makes this an economical install. In the end you have a much more capable system. I do like the CarPlay concept though and look forward to having it in my truck.
DEPO Tail Lights
Old 06-30-2015, 07:48 AM   #5
Reviving this since my interest has really piqued in this now - This is my next project.
BruceH, unfortunately I have the unlimited data plan with AT&T and they don't let you use the hot spot feature unless you switch to a limited data plan. I don't want to leave my unlimited data plan yet.
Pioneer has some sets out that are carplay enabled:
Pioneer CarPlay
Old 06-30-2015, 11:41 AM   #6
jpc763's Avatar
Pioneer CarPlay
I have done the install. I have a 4000NEX receiver with CarPlay and App radio. I never use AppRadio and use CarPlay a lot.
What questions do you have?
John
jpc763 is offline   Reply With Quote
Old 06-30-2015, 12:20 PM   #7
Thanks for responding - here are the questions I have in my head, since you asked
Is it a straightforward install? Does it require any modifications to the bezel or other parts? Did you do it yourself?
How does the data for carplay work? I assume through the phone, but does it use your existing data plan?
I read that it does not pair over bluetooth so it requires re-pairing everytime. If so, how do you make/answer calls?
Is there an included mike on the carplay unit?
Are there a lot of carplay apps out there?
If you had to do it again, would you install it or get an ipad mini instead?
Thanks in advance.
Amit
John
Old 06-30-2015, 03:08 PM   #8
jpc763's Avatar
It is relatively straightforward if you do your homework. There is a lot of info out there to help you do the install. I would recommend that you buy a housing that comes with a wiring harness. Here is one of my threads Installing Pioneer AVH 4000NEX with Euro Motorsport Double DIN
The Euromotorsport housing comes with a bezel and it drops in quite nicely.
I did the install myself. It took a day.
It uses your data plan. If you stream (Spotify) you use data. If you use their GPS app, you use data.
My radio connects via bluetooth if I do not plug the phone in. It is seamless. I am not sure about other models.
The pioneer unit had a mike that I wired up. It works great, even with the top down.
I would not say a LOT. Here is the current list. https://www.apple.com/ios/carplay/
I would do it again. Unless there is a kit for the iPad, I think that I would have had a much harder time installing.
2001 Boxster S - Midnight Blue Metalic
Old 06-30-2015, 04:27 PM   #9
BruceH's Avatar
Thanks in advance.
Amit
I just installed the Poneer 6100NEX in my truck and it is excellent. The touch screen is very responsive. Since you can't use your phone as a hotspot, then get the Pioneer and plug your phone in to use your phone's data plan. The built in GPS is good or you can use Apple maps. Get the proper Metra wiring harness to make the installation simpler. Like JPC763 said, get the Euro Motorsport install kit. The mic that comes with the Pioneer works well. Your phone will connect via blutooth for music and phone calls, but to use CarPlay, and the CarPlay screen, you have to connect via USB/lightning cable. I would not have any regrets installing a Pioneer AVIC 6100NEX into my Boxster rather than the iPad mini. Here is a link to what I got for my truck:
http://www.amazon.com/gp/product/B00SKJH6EQ?psc=1&redirect=true&ref_=oh_aui_detailpage_o06_s01
DEPO Tail Lights
Old 07-02-2015, 03:46 PM   #10
jaykay's Avatar
Amazon.com : Pioneer AVIC-6100NEX In-Dash Navigation AV Receiver with 6.2" WVGA Touchscreen Display : Electronics
If you had to choose one over the other, which would it be? The iPad is much lighter and....
986 00S
Old 07-03-2015, 07:18 AM   #11
Perfectlap's Avatar
AT&T allow tethering with unlimited data plans?
seems like they are the most militant carrier against data sharing for unlimited users.
For limited data plans this car play sounds like a boondoggle for all the carriers. Or do they let you share your limit cap with the car play?
I was looking up the data plans in the new GM wifi cars and it was a good laugh. You won't be streaming video very long with only 1 GB. And going up to only 5 GB (forget HD video) will cost you $70 after you add in the OnStar fees. Which really underlines the importance of SD cards for tablets in family cars. Or pay the pricey premium for more storage if SD card is blocked. Actually I won't buy any mobile device without SD card support and I actually have unlimited Verizon data. I switched from T-Mobile to get in on the unlimited before they ended those plans. I had a feeling that 4G LTE was going to be a big data sucker. But luckily Verizon cant throttle you if your on unlimited because of the spectrum deal they agreed to with the FCC.
BORN: March 2000 - FINLAND
Old 07-02-2015, 03:02 PM   #12
jpc763's Avatar
One thing that irritated me about the Pioneer is that if you want to use App Radio, you need to use USB1 and the HDMI input. If you want to use Car Play than you also have to use USB1 but not the HDMI.
Since I did not want a bunch of cables hanging out of my dash (there is also USB2 and Aux), I got a couple of adapters and mounted them in my cubby.
Here are a couple of pics.
Old 07-02-2015, 04:17 PM   #13
Fintro11's Avatar
I like the look of that , i was going to hard wire my radar detector but then though I would lose the smart cord.
Fintro11 is online now   Reply With Quote
Old 07-05-2015, 06:55 AM   #14
jpc763's Avatar
You can buy a hardwired smart cord. That is what I have. It is wired into the Aux Phone power.
Old 12-13-2018, 03:00 AM   #15
JPC - I love the look of a) the bezel surrounding the unit and b) the fact that you’ve managed to incorporate the USB dock into the back of your cubby. Are you able to direct me to somewhere I can buy the former (can’t find anywhere on the internet! Is there a part number for this retrofit option)? Did you punch a hole in the cubby yourself? If so, any advice? If not, is there somewhere I can purchase one?
Many many thanks in advance!
richardchemistry is offline   Reply With Quote
Old 12-13-2018, 08:06 AM   #16
jpc763's Avatar
Thanks for the compliment! The bezel was part of the install package I got when buying the unit from Crutchfield. For the cubby, I did cut the holes myself. I used a "hole bit" for my drill I picked up at Harbor Freight. Same type of bit you use when cutting a door knob hole. The usb and aux plugs are available on eBay.
Old 07-02-2015, 05:01 PM   #17
BruceH's Avatar
Here is what my truck install looks like. I picked up the USB/Audio jacks on eBay, they fit the Tundra openings perfectly.
DEPO Tail Lights
Old 07-02-2015, 09:10 PM   #18
jaykay's Avatar
I really like the seamless look of the IPad in the 986 ....looks clean and flush. I would probably want a switch to prevent charging all the time. Do you really need the Becker to charge with car off or can this be easily done if one wishes?
I was hoping not use a HU at all.....a Parrot amp and FM radio ap or something
My lower dins will be full.
The pioneer really suits the Tundra dash but would it work as well the Boxster...not sure. What are the USB ports for?????
986 00S
Old 07-03-2015, 12:43 AM   #19
Has anyone used a reciever with MirrorLink? This thread got me searching and I came across the alpine ics x7hd, with the capability to mirror your phone on the reciever touchscreen. Wondering if there's any lag.
I like the simplicity of apple but I like my soundcloud and waze too much.
bobbeck is offline   Reply With Quote
Old 07-03-2015, 06:39 AM   #20
BruceH's Avatar
I love the look too, it really looks great in person. I am not sure how you would keep the Becker from always charging the iPad. I thought about just an amp also, but buying a single DIN HU was the easiest way to get handsfree calling. If you are going to run a radio app, keep in mind that you will need a data plan.
Yes, it does fit the Tundra well, Metra makes a great surround piece that looks OEM. The USB ports are for iPhone/android phone/music player/flash drive etc connection. Remember, for CarPlay to work, it has to be a wired connection. You can play music via Bluetooth but with out the CarPlay interface.There is an HDMI port on the back of the pioneer that I do not have connected. The unit also has a DVD player that you can use while driving via a software bypass. No, I do not recommend watching movies while driving, but listening to a concert DVD is a nice deal.
DEPO Tail Lights
