Old 11-26-2018, 03:34 PM   #1
steved0x's Avatar
and you can go aftermarket on shocks and springs to simulate m030; H&R make an inexpensive lowering spring, and our cars come with bilstein HD shocks; m030 uses the bilstein sport.
I have ridden in a couple cars with the Bilstein sport / h&r springs and they were pretty nice.
Old 11-26-2018, 04:56 PM   #2
edc
550 Anniversary
edc's Avatar
I've had both brand new M030 and old leggy M030 but prefer the car as it currently is on FSD and -10mm M030 spec H&R springs.
Old 11-27-2018, 09:33 AM   #3
The Radium King's Avatar
cool. anyone know the difference between 986 and 987 front sways? otherwise, looks like you could put together an aftermarket m030 system w H&R springs, bilstein sport or koni fsd shocks, and used cayman rear sway. perhaps h&r front sway in a pinch (heavy though, and the h&r rear sway is too stiff unless you like a loose twitchy back end). total cost would be more than you could buy the actual m030 kit from suncoast, i bet.
edit to add: perhaps you could run a cayman front bar with aftermarket drop links? would still be less $ than running a gt3 bar ...
Old 11-27-2018, 11:13 AM   #4
Rennzenn
j.fro's Avatar
I'm pretty sure the 987 parts are a bit wider than the 986 parts. Either the spots where the bars mount to the frames are wider or the full widths of the bars are greater.
Rennzenn
Jfro@rennzenn.com
