Old 11-12-2018, 08:05 AM   #1
After some more troubleshooting i just found that the plastic tube that the Dipstick runs in is broken, see picture. Could it really be that simple?
Stokholm is offline   Reply With Quote
Old 11-12-2018, 08:38 AM   #2
Who's askin'?
maytag's Avatar
Yes, it could be that simple. If that tube is broken then you do, indeed, have a vacuum leak, as the AOS is supplying vacuum to the crankcase.
Definitely fix it. and cross your fingers it's that simple.
Old 11-12-2018, 02:44 PM   #3
jaykay's Avatar
+1
Also check your oil filler tube carefully. I ended up pulling mine apart and resealing the joints.
986 00S
