Old 11-12-2018, 07:29 AM   #1
Is this a normal sound?
All,
I am doing some troubleshooting on my 2001 Boxster S. The car fells a little slugish on the gas, especially in low rpmīs and I have also had a few engine lights pointing to O2 sensors. All O2 sensors are now new, all filters, air and oil have been replaced and today I cleaned the throttle body. It runs a little smoother but it still sounds like it is gasping a little for air when I push the throttle. Is this normal or do I have a vacum leak somewhere? I shot a video of the gasping sound:
https://www.youtube.com/watch?v=hywsIBly4Jk&feature=youtu.be
Stokholm is offline   Reply With Quote
Old 11-12-2018, 07:46 AM   #2
1998 Boxster Silver/Red
Originally Posted by Stokholm View Post
All,
98 2.5
Mine makes that same sound. Looking forward to the responses.
1998 Porsche Boxster
Old 11-12-2018, 08:05 AM   #3
After some more troubleshooting i just found that the plastic tube that the Dipstick runs in is broken, see picture. Could it really be that simple?
Old 11-12-2018, 08:38 AM   #4
Who's askin'?
maytag's Avatar
Yes, it could be that simple. If that tube is broken then you do, indeed, have a vacuum leak, as the AOS is supplying vacuum to the crankcase.
Definitely fix it. and cross your fingers it's that simple.
Old 11-12-2018, 02:44 PM   #5
jaykay's Avatar
+1
Also check your oil filler tube carefully. I ended up pulling mine apart and resealing the joints.
986 00S
Old 11-12-2018, 02:55 PM   #6
gman1113's Avatar
Have you changed the mass air flow sensor. I had the same thing on my 2000 S and also put new O2 sensors in and it didn’t fix it. Changed the MAS and problem solved.
gman1113 is offline   Reply With Quote
Old 11-12-2018, 04:09 PM   #7
All,
When I open the throttle very fast, I do hear that air gasp a moment before the engine revs up, but it is always like this and no check engine light or noticeable power loss/ sluggishness.... It is even more noticeable after I installed a larger 996 TB but I thought it is quite normal with original air box and intake system.
It is interesting if this is definitely abnormal, I may be missing something and a few horse powers???
Old 11-12-2018, 04:35 PM   #8
Arghhhhh. I'll have to do some inspecting, myself, and see from where my little gasp is coming. (Hint: It's not my wife).
