Old 09-11-2018, 04:32 AM   #1
flouese's Avatar
Ready to start after rebuild
My motor replacement took such a long time (3 months) due to being in the rainy season and work, I am finally ready to try and start it (2.5L) for the first time. Full of fresh oil, replaced transmission fluid, brakes bled, master cylinder replaced.
Only issue I currently know of is my post cat O2 sensors are not connected since the replacement cats do not have a bung to insert the sensor. Will this be a problem with startup? My intentions are once the car starts take it to a shop that will install the bungs in the proper location.
Are there any tidbits that will save me a lot of aggravation and frustration after I turn the key for the first time?
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 09-11-2018, 09:33 AM   #2
Porsche "Purist"
Paul's Avatar
No issue with startup. Have a fire extinguisher handy and a plan to get your car outside if necessary.
1987 924S. 2002 996TT. PST-2
Old 09-12-2018, 09:57 AM   #3
flouese's Avatar
This is all the advise and pointers the forum could come up with? After the amount of time, effort and money I put into this, I am hoping not to screw anything up by not doing a pre-start up check of some sort. PLEASE ADVISE!!!
99 Boxster base
1966 912 3 gauge
Old 09-12-2018, 11:20 AM   #4
Ok, what about following Jake Raby recommendations..?
He cranks the engine right before starts running and shuts it off immediately, this is to allow the engine to build oil pressure, and repeats this procedure a few times until the internal components are properly lubed, then starts the engine and lets it warm properly,
it makes a lot of sense.
Old 09-12-2018, 12:05 PM   #5
flouese's Avatar
Thanks. This is what I am looking for.
99 Boxster base
1966 912 3 gauge
Old 09-12-2018, 01:07 PM   #6
...and then have a fire extinguisher ready...
garv214 is offline   Reply With Quote
Old 09-12-2018, 03:27 PM   #7
Porsche "Purist"
Paul's Avatar
Since it is a used motor no break in is needed, double check all your connections and fluid levels. Open the coolant tank vent. With the engine cover off, have an assistant standing by with a fire extinguisher and have him watch for leaks (especially fuel). Shutdown if anything is leaking, no oil pressure, or excessive noise.
Old 09-12-2018, 03:34 PM   #8
Motorist & Coffee Drinker
78F350's Avatar
Lastly, have a spectator standing by recording it on video and capturing your big grin. The first start only happens once.
Old 09-12-2018, 09:43 PM   #9
Cunningr's Avatar
Prayer to engine god! After double checking there is oil in the engine! Lol good luck
Old 09-13-2018, 04:25 AM   #10
flouese's Avatar
Appreciate the assist. Saturday will be the day... I will either be smiling or saying a whole bunch of Sailor words I haven't used since I retired from the Navy!
99 Boxster base
1966 912 3 gauge
Old 09-13-2018, 04:45 AM   #11
Multi-Boxer Driver
Deserion's Avatar
Why not both? Good luck!
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 09-13-2018, 04:41 PM   #12
flouese's Avatar
You can always swing by Callahan and enjoy the show!
99 Boxster base
1966 912 3 gauge
Old 09-16-2018, 08:51 AM   #13
flouese's Avatar
UPDATE: Engine started up fine, runs smooth and sounds good and no CEL even with the post cat O2 sensors not connected. However, Have a coolant leak from the "3-way hose". Problem is the overflow hose starts draining at a small stream at just above normal operating temps (slightly to the right of the 8 in 180). Any thoughts?
99 Boxster base
1966 912 3 gauge
