09-09-2018, 05:20 PM
Has anyone done front wheel bearings DIY?
I'm pretty certain my vibration issues is due to bad front bearings because I have literally replaced every other steering and suspension component and it's still there.
Has anyone done this DIY? I have a few questions:
1. How challenging is it? I've done struts, control arms, tie rods, etc.
2. I'm guessing I need the SIR kit to extract the bearing - is there any way to get it cheaper than the $390 that Pelican wants for it?
3. Is it necessary to take the carrier off the car to do this? I had a ball joint remover, but it's a cheap one from O'Reilly that I used for my coffin arms and tie rods replacement when it didn't matter if I ripped the rubber boots. Should I buy the Porsche specific one? Or is there another tool? I just replaced the control arms and tie rods, so I really don't want to rip the rubber on those.
4. Are the FAG brand bearings considered good quality?
09-09-2018, 05:47 PM
Yes
Fronts much easier than the back and easier than struts in my opinion.
Otc grappler puller plus harbor freight bearing press plates, much cheaper, there is a thread here somewhere.
No, should be able to do without removing the carrier or popping the ball joints. You do need the carrier to drop down a little so the strut bottom will clear the back side of the bearing to remove the stub axle and get the press tools in there, so you can remove the top bolt off the sway bar link (so the carrier will slide down the strut) and maybe loosen the inner LCA bushing so that arm will pivot down. Maybe remove the tie rod ball joint if that blocks you but that is the easy one.
I used F.A.G. for mine when i did them in early 2016, still going strong many miles and track days later.
Steve
Reason: Edit to say "top" sway bar bolt
09-09-2018, 05:59 PM
I've done front and rear. Fronts were easier due to not having to screw with the parking brake mechanism.
I didn't use the SIR tool but simply removed the hub and pressed out the bearing. Even if you have a shop R/R the bearing from the hub, it'll be cheaper than buying the SIR tool. Not dissing the tool...you could buy it, use it and sell it on if you want.
Remember to buy new axle nuts!
09-09-2018, 06:26 PM
Originally Posted by steved0x
Yes
No, should be able to do without removing the carrier or popping the ball joints. You do need the carrier to drop down a little so the strut bottom will clear the back side of the bearing to remove the stub axle and get the press tools in there, so you can remove the bottom bolt off the swqy bar link and maybe loosen the inner LCA bushing so that arm will pivot down. Maybe remove the tie rod ball joint if that blocks you but that is the easy one.
Steve
So would this:
https://www.amazon.com/OTC-6575-1-Hub-Grappler-Puller/dp/B005PL1PDA/ref=redir_mobile_desktop?_encoding=UTF8&ref_=mp_s_a_1_2
Plus this:
https://www.amazon.com/dp/B075YS3MRH/ref=dp_cerb_2
Work?
Also, is the torque spec for the axle nut the same in the front as it is in the rear? 340ft/lbs?
09-09-2018, 06:28 PM
Is the axle nut torque the same for both? What tool did you use to press out the bearing?
09-09-2018, 06:43 PM
Simply asking
If anyone had experience with Federal tires, from many reviews (not by manufacturer or sellers) they are decent tires....BTY you can buy most any tire on Ebay from Michelin PAX tires to replacement RC foam tires
sorry wrong thread
Reason: posted in wrong area
09-10-2018, 03:03 AM
I did my bearings with the HF tool. What Steve said above. If you have done everything else wheel bearings should be easy for you.
99 Porsche Boxster
09-10-2018, 06:57 AM
Out of curiosity. What does the vibration feel like as I am trying to track down steering wheel vibration around 75-77mph and again around 88mph or so.
09-10-2018, 08:16 AM
Are you referring to this tool?
https://www.harborfreight.com/front-wheel-bearing-adapters-63728.html
Did you have to use any other tools in conjunction with it?
09-10-2018, 08:17 AM
It's a very slight judder/vibration that seems to be coming from the front left. When I'm driving on rough roads, the wheel shakes more than it should. I also seem to have a bit of slop in the steering / the car kinda fights me when I turn in hard.
What is yours like? Have you replaced any suspension components?
09-10-2018, 08:48 AM
Originally Posted by speedyspaghetti
If you use this, you still need something to pull the hub which can be a slide hammer or some folks have used lug bolts and pressed it out by pushing against the carrier, I have only seen videos of this with other cars though.
I don't know which of the Amazon kits, here is the thread but it doesn't say which kit:
https://986forum.com/forums/boxster-general-discussions/72020-wheel-bearing-replacement.html
09-10-2018, 09:32 AM
Ok, so the OTC grappler would be used for the hub? Or would I still need a slide hammer to get the hub out?
09-10-2018, 09:37 AM
Top down
 every day is a great day when you are driving a Boxster
09-10-2018, 10:36 AM
Yes, the OTC grappler is for pulling the hub, the press kit is used for pulling the bearing, pressing the new bearing in, and pressing the hub back in.
09-10-2018, 11:20 AM
Gotcha. Ok, I'm gonna go ahead and do the OTC + Amazon tools and then I'll try to make either a video or write-up DIY on the bearings since I haven't found anything excellent in that realm for our cars.
09-10-2018, 03:49 PM
Pathological Tinkerer
I used the Harbor Freight Front Wheel Bearing Kit and a bearing separator. Left the upright attached to the lower control arm, tie rod, strut. There is a youtube video of a guy using the kit to do a BMW E46 rear wheel bearing for some instruction.
09-10-2018, 04:20 PM
I bought one of these from Harbor Freight and it works to pull out the bearing and install the new bearing. I bought the puller, CTA Tools Bracket Assembly (3) - 8653 and made the spacer at work. got it from Auto Body Toolmart for 132.96
https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwjUoOeYmbPdAhWMisgKHStgDUkYABAIGgJxdQ&ohost=www.google.com&cid=CAESEeD2tnT37JmljLn7EOYAvDCU&sig=AOD64_2cvl_phRMnRLh8NeHdNgogYWZ33g&ctype=5&q=&ved=0ahUKEwjN8d6YmbPdAhXqct8KHRJ5DccQ9A4IwQE&adurl=
09-10-2018, 06:03 PM
Freeze the new bearing before you press it in
09-11-2018, 10:32 AM
What is the spacer for?
