Old 05-18-2021, 03:22 AM   #21
PhoenixBlue
Originally Posted by TiberiusBoxster View Post
That was it. Pulled the connectir and ran a ground lead and a positive lead. Buttoned it back up and it works. I need to do some more plasti dip in there, but that will get me pass inspection.
Thanks again.
Hi sorry to drag this thread up from the dead, but I seem to have the same problem, and am an idiot when it comes to electrics/wiring - what did you do that solved the problem? Was it just cleaning the socket that was required?
PhoenixBlue is offline   Reply With Quote
Old 05-21-2021, 08:12 PM   #22
PhoenixBlue
Turn the headlights on (to parking light position), then test at the car side connector between common ground and parking light +, just to be 100% sure you have good power between the two (unless you already did that).
PW, hope you can help! I have this exact problem, but I have connectivity on the headlight side, and power on the car side (by testing the connectors). What else could it be?
