Old 06-04-2018, 11:06 AM   #1
2000 S cranked but doesnt star
Round one; dead on road; towed home, pulled codes, replaced CPS sensor.
Round 2 and 3, at gas station both times, post fillup. Cranked did not start, approximately 5-10 minutes later, did fire.
Pulled codes;
P0410, P1411, P0446.
Would these account for issue as described?
Thanks.
David
Luckyman01 is offline   Reply With Quote
Old 06-04-2018, 11:34 AM   #2
Round 2 and 3, at gas station both times, post fillup. Cranked did not start, approximately 5-10 minutes later, did fire. EVAP purge valve
Pulled codes;
P0410, P1411, SAI system failure, will not keep car from starting (could be bad air pump, but likely bad vacuum or valve)
P0446. EVAP purge valve
Thanks.
David
The EVAP purge valve is why your car won't start after fueling. Could also be gas cap.
Old 06-04-2018, 02:52 PM   #3
particle wave, thanks for quick reply; I think my take away is replace EVAP purge valve and gas cap.
However on the answer "SAI system failure, will not keep car from starting (could be bad air pump, but likely bad vacuum or valve), are you suggesting the EVAP purge valve or yet another?
