Old 06-04-2018, 11:34 AM   #2
particlewave
Originally Posted by Luckyman01 View Post
Round one; dead on road; towed home, pulled codes, replaced CPS sensor.
Round 2 and 3, at gas station both times, post fillup. Cranked did not start, approximately 5-10 minutes later, did fire. EVAP purge valve
Pulled codes;
P0410, P1411, SAI system failure, will not keep car from starting (could be bad air pump, but likely bad vacuum or valve)
P0446. EVAP purge valve
Would these account for issue as described?
Thanks.
David
The EVAP purge valve is why your car won't start after fueling. Could also be gas cap.
particlewave is online now   Reply With Quote
