Old 06-04-2018, 01:52 PM   #3
Luckyman01
particle wave, thanks for quick reply; I think my take away is replace EVAP purge valve and gas cap.
However on the answer "SAI system failure, will not keep car from starting (could be bad air pump, but likely bad vacuum or valve), are you suggesting the EVAP purge valve or yet another?
Luckyman01 is offline   Reply With Quote
