Old 05-18-2018, 04:43 PM   #1
DarkStar's Avatar
Spindle/hub differences?
I had a question. Are the spindle/hubs on the 2.5 the same as the 3.2?
DarkStar is offline   Reply With Quote
Old 05-18-2018, 05:49 PM   #2
98 Arctic silver 986
tommy583's Avatar
The rears are definitely different, the fronts my be the same.
Old 05-18-2018, 05:52 PM   #3
78F350's Avatar
Not the same.
5-speed (2.5L) axle in 2000 S (3.2L) hub:
5-speed axle is shorter, but fits in the hub.
Transmission end. 5-speed vs 6 speed stub (2000 S on left 5-speed on right):
The axle mount to the transmission is different diameter and design.
Old 05-18-2018, 09:42 PM   #4
DarkStar's Avatar
I ask because I need one for some prototype fab work. And rather than tear mine down, I know my local junk yard has one that rolled and could rip one off of it. I do need mainly the front Spindle and Hub.
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
Old 05-19-2018, 09:59 AM   #5
steved0x's Avatar
I think the fronts are the same on the 3.2/2.7 and maybe the 2.5, I bet Woody would know.
Old 05-20-2018, 12:42 PM   #6
DarkStar's Avatar
I bet he would too. I should text him. IDK why I didn't think of that.
-Josh
Old 05-20-2018, 05:12 PM   #7
As far as I know all 986 and 996 use the same front. The rear 2.5 and 2.7 are the same but the S has much beefier rear pieces. The stub that the nut screws onto is the same size though. You can put a base axle on a S carrier but you can't put a S axle on a base carrier without some machining of the base carrier
Woody
Old 05-20-2018, 07:25 PM   #8
steved0x's Avatar
I always wondered if the rear S pieces could be used on the front and allow the bigger wheel bearings to be used. Just idle thoughts
Old 05-20-2018, 09:01 PM   #9
I know of someone in the racing world that was going to attempt that. They must have ran into a problem as they never used it on their car. I always mean to ask them what happen but forget to when I see them.
Woody
Old 05-21-2018, 02:34 PM   #10
DarkStar's Avatar
I honestly hate that 01S+ Bearing. Because I was unaware it is like a special order only part and only select places sell it, and they were all on backorder... So took me a month from tearing down my car, to getting it back on the road. Was the most expensive bearing on the planet since I had to rent a car for almost a month!
-Josh
