Old 05-10-2018, 08:28 AM   #1
flouese's Avatar
1999 2.5l removal & replace
Two point 5 questions:
1. I've seen a lot of different numbers but what is the actual height off the ground do I have to get the car to drop and ultimately replace my 2.5L motor?
2. Can the IMS be removed and replaced for inspection? (a) I want to see if the one installed on the engine 10K miles ago is good and (b) if the one in the engine I am replacing it with is good. If I can remove and reinstall it, what would I look for?
2.5 Does anyone have an IMS tool they are willing to loan (ship) so I can do the above process?
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 05-10-2018, 08:35 AM   #2
1. 24 inches would be useful.
2. No, removing the IMS bearing kills it, it cannot be reinstalled.
3. No.
Old 05-10-2018, 11:17 AM   #3
I walked out and measured, the engine itself is 23" tall when sitting on the sump. Remember to include additional room for anything under the engine (like a furniture dolly so you can roll it out from under the car).
Old 05-10-2018, 06:45 PM   #4
As for question #2, you can identify and inspect the bearing by removing the IMS flange (don’t forget to lock the timing and remove the chain tensioners) but, like JFP says, once the bearing is pulled it cannot be pressed back in. It should be pointed out though that once you have removed the IMS flange it would only take an additional 30 min to install a fresh bearing.
roundel325 is offline   Reply With Quote
Old 05-11-2018, 04:01 AM   #5
flouese's Avatar
Thanks for the responses. I guess this weekend I will attempt into this project. Anyone in N. FL want to assist??? All the beer and pizza...
99 Boxster base
1966 912 3 gauge
Old 11-21-2018, 10:39 AM   #6
Will there be cake?
tonythetiger's Avatar
quick question
how do you get the car off the ground 26 or 27 inches without a true lift, my jackstands are only 16.5 inches and shopping for taller ones seems that 2 pairs are the price of a lift!
suggestions out there?
Old 11-21-2018, 11:12 AM   #7
There Is No Substitute.
rick3000's Avatar
Did your '99 have an IMS failure?
The '99 has the dual row IMS which isn't prone to the high failure rate that began in '00.
Old 11-21-2018, 12:06 PM   #8
Originally Posted by tonythetiger View Post
quick question
I have four of these. 52" jack stands. 2500 lb rating. Four will run $309 so they are reasonably affordable. They work great. I use a block of 2x4 wood between the jackstand and the car if I am lifting directly.
Amazon Ridgid 58 Inch Jackstand
If you want something more stout: 46" jack stands. 10 ton rating. Two sets will run $400. Still reasonably priced.
Amazon Sunex 46 Inch Jackstand
Old 11-21-2018, 03:50 PM   #9
jaykay's Avatar
My 2 cents........you will have to look for something that will stroke more than the lift height you need or get the car up such that you can jack from a riser that can be increased in height as the car is elevated. Not easy as one would have to get the jack up on the riser every time for the rear where the engine is.
My low profile jack only gives me a max of 24" so I don't engage in engine removal operations. It is too long and heavy to get up on to a riser.
I have definitely seen folks with engine out on the floor.....on stands. You might want research and contact for information on the equipment used. Would sliming down your engine removal skid give you more clearance?
986 00S
