Old 03-14-2018, 10:41 PM   #1
18 inch 987.1/987.2 boxster Cayman wheels
I've got an opportunity to purchase four (4) 18 inch wheels from a MY 2005 Boxster or Cayman.
They have the standard 130mm bolt pattern. These are the offsets:
2x 8J Offset ET57
2x 9J Offset ET43
Will they fit a 1999 Boxster?
MNC-I
mnc-i is offline   Reply With Quote
Old 03-14-2018, 11:53 PM   #2
They are the same offsets as the 18” Caymans I have put on my 03 S.
The fit for the rear is perfect I think. For the front I have 7mm spacers to install but they fit without them with no rubbing on the inside strut. I want the spacer to push them out a little. 10mm would be ideal as I want to keep the staggered track. No need for spacers on the rear I think but you could fit some if you wanted a wider look.
They fill the arches much better and the view from the rear is more purposeful. Very pleased with them and will keep the 17” for track use with a more track orientated tyre.
Not sure why tire sizes you have but with the 18’s and the wider tires there is a lot more grip so for our wet twisty Irish roads the extra security is nice.
Sent from my iPhone using Tapatalk Pro
Traco
_________________
Older but no wiser.
2003 Boxster S, Seal Grey
Traco is offline   Reply With Quote
Old 03-16-2018, 05:22 PM   #3
Traco,
Thanks for the quick reply.
Based on your reply, I am going to purchase the wheels and put on 18 inch tires per model year 2005.
https://austin.craigslist.org/pts/d/factory-aluminum-wheels-18/6527799692.html
Thanks again.
MNC-I
Old 03-16-2018, 05:54 PM   #4
steved0x's Avatar
Originally Posted by mnc-i View Post
Traco,
Thanks again.
MNC-I
I think I saw you had a 1999? If so, don't go with the 2005 tires sizes, you want ones that are closer to a 25" diameter, I think 225/40/18 and 265/35/18 are the 986 Boxster tock 18" sizes. The 2005 sizes may work but may not be optomal.
Smoking deals on those wheels too
