Old 02-03-2018, 10:26 AM   #4
Originally Posted by thom4782 View Post
Thanks.
Does this mean that there is something mechanically wrong that needs repair. Or does this mean that the transmission is becoming noisy as it ages? If it's simply aging, should one use a different transmission fluid to extend the life as long as possible
FWIW: I did not replace the dual mass flywheel when I replaced the clutch at 125K or roughly 40K ago.
it means you need a new flywheel.......
