Old 01-10-2018, 07:11 AM   #1
gabedrummin's Avatar
Oil Pressure Sending Unit
I have a 986 . I would like to use a 996 oil pressure sending unit an add a pressure gauge. Dose anyone know the specs of the sending unit ? Ohm range ? I know its 12 volts. Thanks for all your help guys.Sending unit 996-606-203-03-m100..VDO Will not give out the info.
Old 01-10-2018, 08:30 AM   #2
steved0x's Avatar
It is this one:
For oil pressure, you could buy the more expen$ive Porsche part, but it is just the same as this part:
VDO 360028
http://www.amazon.com/VDO-360-028-Pressure-Sender/dp/B00T9JZP58?ie=UTF8&keywords=vdo%20360028&qid=1465305077&ref_=sr_1_1&s=automotive&sr=1-1
https://www.vdo-gauges.com/sensors/pressure-sensors-switches/pressure-sensor-with-warning-contact/pressure-sender-80-psi-warning-contact-7-1-psi-m14x1-5-30-28.html
VDO 360-028: 80 psi Pressure Sender Warning on Contact 7.1 PSI | JEGS
this is an 80 PSI sender and I used this gauge:
VDO 350104
http://www.amazon.com/VDO-350104-Electrical-Pressure-Diameter/dp/B000CCDLEI?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_search_detailpage
I think I have one, I somehow ended up with 2 when I ordered them for my car, I will sell it for half price plus shipping if I can find it
Old 01-10-2018, 09:30 AM   #3
You rock sir...10/180 is what I was looking for .I appreciate the offer but I need a white face gauge thank you sir for the info. Dose the gauge have to match or be within the range.?
Old 01-10-2018, 09:59 AM   #4
steved0x's Avatar
I don't have an extra gauge, I have [edit: may have if I can find it] an extra sender I could have worded that a little bit better.
I don't know how or if that sender could be used with other gauges besides the VDO gauge or the 996 cluster gauge (and I personally have only ever used it with the VDO gauge listed)
Old 01-10-2018, 10:42 AM   #5
Dave80GTSi's Avatar
[QUOTE=gabedrummin;559906] I need a white face gauge [QUOTE]
See my post no. 4 here: Please post your pictures of auxiliary center gauges!
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
Dave80GTSi is online now   Reply With Quote
Old 01-10-2018, 12:08 PM   #6
Artist, 986S tinkerer
NewArt's Avatar
I used a VDO Ivory gauge from egauges.com.
