Old 12-11-2017, 09:01 PM   #1
Pathological Tinkerer
04 Anniversary Edition Sport Suspension
With the onset of winter, the car will now live on jack stands for a month or so while I complete my 987 airbox/997 TB/Tee installation and upgrade my suspension. The airbox/TB install is almost complete with just plumbing delivery holding me up.
For the suspension upgrade, I was able to source the complete sport suspension package from a California based 04 550 with 35k miles. Parts look to be in great shape.
Upon receiving the parts, I measured the bars and came up with 24.5mm for the front and 20mm for the rear. Also, the rear bar has a sticker on it with a part number 98633370118. Based on the information out about the 986 S m030 bars, 24mm for the fronts and 19.8 for the rear, these bars seem to be a bit larger than the normal 986 S m030 bars.
Also, I can't find the rear bar part number in any Porsche catalog or dealer part site. It looks like the 550 sport suspension bars are even stiffer than the normal 986 S m030 bars. Is this correct and Porsche upgraded the 550 suspension above the normal m030 or am I missing something?
P_Carfahrer is offline   Reply With Quote
Old 12-12-2017, 04:02 AM   #2
steved0x's Avatar
M030 for 986 S is 24mm front and 19mm rear:
Drilling an extra hole in a sway bar end to give a softer setting
Old 12-12-2017, 11:07 AM   #3
Steve, then it seems Porsche put one off bars in the 550 edition that are a bit stiffer.
The two dealerships I have called can't tell me anything about it, especially that rear bar part number.
Old 12-12-2017, 11:27 AM   #4
steved0x's Avatar
That screenshot was of the rear bar? 986.333.701.18?
986.333.701.21 is the rear M030 986 S bar, maybe it is a revision of the older 18 bar (which I couldn't find any mention of either...)
Old 12-12-2017, 01:59 PM   #5
"50 Years of 550 Spyder"
10/10ths's Avatar
I own a 550 SE....
...I will go out there and measure mine tomorrow.
I have a new, in the box, ROW 030 kit in my garage and the sways in that kit are 24/19.
Old 12-12-2017, 02:57 PM   #6
edc
550 Anniversary
edc's Avatar
Is it from a tiptronic car? The tip had stiffer rear springs but I used a tip kit on my old manual. Just junked my leggy manual M030 springs and dampers for Koni FSD /H&R.
Old 12-12-2017, 03:28 PM   #7
10/10ths - That will be good to see what you come up with.
Steve- Yes the .18 part number is from the sticker on the rear bar. Also, in reviewing the PET catalog, in 04 it looks like Porsche made additional distinction between the S m030 bar and the S 6MT was built with the thicker base m030 bar. At least that is how I read the PET. Am I not reading this right?
Old 12-12-2017, 04:17 PM   #8
steved0x's Avatar
I can't read the image on my phone, maybe the 550 did get something special?
Old 12-14-2017, 12:22 PM   #9
10/10ths's Avatar
Ok....
....my six-speed manual 2004 Boxster S "50 Years of 550 Spyder" edition Boxster 986 has 24/19 mm sway bars EXACTLY the same diameter as the sway bars in my ROW M030 kit I have sitting here. The sway bars are the same for USA & ROW M030 kits.
Old 12-14-2017, 07:04 PM   #10
Hmmm....
I wonder what I have then, especially with the 986.333.701.18 bar number. Guess it will remain an unsolved mystery.
The 24.5mm front and 20mm rear poly bushings I bought fit perfectly though.
Old 12-15-2017, 03:40 AM   #11
10/10ths's Avatar
Automatic transmission?
