Old 11-15-2017, 02:58 PM   #1
JonnyReverb's Avatar
Rain tray replacement tutorial
Hey Everyone,
I got a new rain tray (thanks for the pointers on the problem), but I can't find a tutorial on replacement here, on Pelican, or on Youtube.
Anyone got a link?
Thanks,
Jonny
JonnyReverb is offline   Reply With Quote
Old 11-15-2017, 03:12 PM   #2
1999 base
Meir's Avatar
What is a rain tray
Old 11-16-2017, 12:02 AM   #3
Originally Posted by JonnyReverb View Post
Hey Everyone,
Anyone got a link?
Thanks,
Jonny
Which vehicle? Boxster's don't have a "rain tray", 911's do. If by rain tray, you mean the plastic part that goes under the wiper cowl, it's pretty simple. Remove the cowl, the tray is directly beneath just snaps in place. If you mean that on the 911 or Cayman models, that goes between the inlets on the rear deck over the engine.
RobertKing is offline   Reply With Quote
Old 11-16-2017, 03:05 AM   #4
I believe he's talking about the foam inserts that are located where the convertible mechanisms are located. Here I am the parts guy and I dont even know what they're called. As for replacing them, you'll want to remove your top. Three bolts on each side, tension cable and the control arm. It takes about 15 minutes and it helps if you have someone there with you. Once you get the top out of the way it's pretty self-explanatory.
Woody
Old 11-16-2017, 03:46 AM   #5
KevinH1990's Avatar
You can find some photos of the process Woody described here:
https://sites.google.com/site/mikefocke2/installinga%2703-%2704glasstopandframeona%2797
Tags
rain guard , rain tray , water leak
