Old 11-01-2017, 03:48 PM   #1
Any way to remove ignition cylinder or steering lock without key?
I acquired a 2001 Boxster S with no keys to use for parts. I bought and waited for a service key from Porsche so I could turn on the ignition for testing the electrical and unlocking the steering so I could move the car around. I don't need to start it at this moment. I sadly found that the ignition lock has been replaced in this car already so my new key doesn't work. I doubt I'll ever be able to get the right key for it.
The problem is now that I need to change the ignition I can't get it out. Since I can't turn the key in the ignition I can't disengage the steering lock and in turn it won't come out of the steering column. I disassembled things all the way and I'm down to the point where you would depress the locking pin with a small screwdriver to release it from the column, but it won't depress since it's locked.
Anybody have a clue how to deal with this?
deathsled986 is offline   Reply With Quote
Old 11-01-2017, 05:49 PM   #2
You don't sound like a very good car thief.
Old 11-01-2017, 07:14 PM   #3
1997 Tip, 2018 Macan
rexcramer's Avatar
Go 'old skool', drill it and use a slide hammer to pull the cylinder?
Old 11-02-2017, 04:01 AM   #4
On a 2001, you should be able to remove a part of the steering column shaft. You won’t be able to use the steering wheel but you’ll be able to manually turn the front wheels. Only takes like five minutes
Woody
Old 11-02-2017, 01:52 PM   #5
I ended up busting out the ignition housing around the cylinder. Cylinder came right out after that and I was able to unlock the steering finally
Old 11-02-2017, 07:52 PM   #6
Where's my car, did you steal it???
Old 06-02-2018, 10:25 AM   #7
Im having the same issue. How did you do it. I cant get the pin to press.
mykelamy is offline   Reply With Quote
