Any way to remove ignition cylinder or steering lock without key?
I acquired a 2001 Boxster S with no keys to use for parts. I bought and waited for a service key from Porsche so I could turn on the ignition for testing the electrical and unlocking the steering so I could move the car around. I don't need to start it at this moment. I sadly found that the ignition lock has been replaced in this car already so my new key doesn't work. I doubt I'll ever be able to get the right key for it.
The problem is now that I need to change the ignition I can't get it out. Since I can't turn the key in the ignition I can't disengage the steering lock and in turn it won't come out of the steering column. I disassembled things all the way and I'm down to the point where you would depress the locking pin with a small screwdriver to release it from the column, but it won't depress since it's locked.
Anybody have a clue how to deal with this?
