Old 10-22-2017, 04:29 PM   #1
Ciao's Avatar
Brake Reservoir Lid Removal
I flushed out brake fluid with Power Bleeder, but could not take out the plastic lid from the reservoir. Didn't was to force it; does it come out? Any tips/suggestions for next time?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 10-22-2017, 05:07 PM   #2
Mine stays in as well! I just use the motive dry to apply pressure and flush. Just keep an eye on the fluid level....It works well this way.
Old 10-22-2017, 05:17 PM   #3
steved0x's Avatar
You can kind of grab the edges with a needle nose and rotate it a little and pop it out. It's fiddly. I only do it when I'm doing a complete flush which is rare since I bleed so much. Last time I did was when I switched from Ate 200 to Motul 600.
Old 10-22-2017, 05:53 PM   #4
Ciao's Avatar
That's worth a try and a good option!
Old 10-22-2017, 05:55 PM   #5
Ciao's Avatar
I tried that, perhaps I should be more patient
Old 10-23-2017, 04:27 AM   #6
husker boxster's Avatar
You might need to take a small screw driver to lift the edge, then grab with a needle nose pliers.
1989 928 S4 5 spd - black
