Old 10-05-2017, 01:29 PM   #1
JBauer's Avatar
Headlight in oven 😲
My new headlight is supposed to be here tomorrow and, even though some pretty knowledgeable member have told me the oven story, it still was creeping me out. I was afraid to ruin a brand new headlight but here's a link to some instructions really good instructions i found on the manufacturer M-Ms web site. I feel more confident now.
Old 10-05-2017, 04:04 PM   #2
I have two extra lights I am going to try this with.
However, I'm going cheap and not putting a lens inside.
I will use them without it there.
Fuzzuki is offline   Reply With Quote
Old 10-05-2017, 04:05 PM   #3
I have the Nine8Six projector headlight conversion from this thread in the DIY section. I was chicken to do it myself so I had it done. But in that thread are these instructions. See the section on baking the headlight in the oven. You want to put some wood in the over and put the headlight on the wood, not directly on the metal grates in the oven. (Even though you only want the lens).
I would attach those instructions here, but they are a pdf and I can't attach that through the photo upload feature.
Old 10-05-2017, 05:08 PM   #4
225f for 15 minutes. Make sure no part of the headlight is touching anything metal in the oven (resting on wood blocks, as said above).
Old 10-05-2017, 07:53 PM   #5
redciv1's Avatar
I put my headlights on a pizza pan with aluminum foil underneath.
redciv1 is offline   Reply With Quote
Old 10-06-2017, 03:05 AM   #6
flouese's Avatar
Where can you find new/replacement lenses?
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
Old 10-06-2017, 03:40 AM   #7
JBauer's Avatar
Nowhere that I could find. Unfortunately.
Old 10-06-2017, 03:46 AM   #8
JBauer's Avatar
I may end up switching the internals and using the new case, depends on the difficulty.
My pics are PDFs. You just have to "go advanced" when you edit your post.
Old 10-06-2017, 03:47 AM   #9
JBauer's Avatar
What temp? How long?
Old 10-06-2017, 05:36 AM   #10
I would go with Particlewave's 225 F for 15 minutes if I was doing it!
Old 10-06-2017, 06:32 AM   #11
BruceH's Avatar
Yes, I would take the expert's advice
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 10-06-2017, 07:42 AM   #12
You can buy replacement inner lenses here:
http:// www.sierra madrecollection.com/Headlight-Lens-Set-986-996-99-05-p32132.html
Old 10-06-2017, 11:01 AM   #13
Ahh, you like them crispy on the outside and soft on the inside
Old 10-06-2017, 11:47 AM   #14
JBauer's Avatar
Sweet 😁
Old 10-06-2017, 11:54 AM   #15
JBauer's Avatar
Ya I looked there. Just saw whole assembles. I wish they sold just the clear lens ☹
Thanks for the info tho.
Old 10-06-2017, 11:57 AM   #16
CoBeerToad's Avatar
I didn't have that kind of time, so I used the microwave.
For future reference, don't use the microwave.
CoBeerToad is offline   Reply With Quote
Old 10-06-2017, 01:43 PM   #17
Nine8Six's Avatar
microwave..., defrost cycle for 1:30min. sweet LOLL
I use/recycle the thick box, as in the same box the headlight came packaged into. I feed it a heat gun on its side (set to medium) for 20min lolll Just need some sort of reflector to make sure the heat don't blow directly on the headlight. Box is disposable, wife is happy'er
Our headlights don't necessarily need to be melted. 20~25dC warmer than ambient and they pretty much let go without a fight. Well, not a huge fight anyway (cat fight!!).
Glad to see you've sorted this out, ouch man :/
Old 10-06-2017, 01:51 PM   #18
My response was to flouese. I took his question as meaning replacing the burnt inner lens, as in the first post. The main outer lens is not sold separately.
Old 10-06-2017, 01:55 PM   #19
After doing 100+ sets of these, I've found that 225f for 15 minutes is the ideal temp/time.
No sense in screwing around with a heat gun. I've had too many people come crying to me about melting their main outer lens by using the "heat gun and cardboard box" method and wanting me to fix it.
Old 10-06-2017, 04:24 PM   #20
Nine8Six's Avatar
100+ sets, fine if you have a dedicated oven in the corner of the garage. I'm less fortunate on that priviledge. Got caugt once-too-many-time with my own headlight in the kitchen oven ~ at the time (I know... wicked stuff loll). If you would have heard her scream I swear you'd think someone was murdered. My right side devil got so distured he told me to stop immediately loll
Charles - the reasonaing behind the Box idea and lower temp (ambiant +25dC) is to prevent deformation. Not that 225F will 'automatically' deform the bosch assembly, but some of us (cheap-boxes operators!) feel more comfortable staying within <50% of the softening point of polycarbonate (lense) and PP (hsng). When force is applied while the unit is really hot, the chances of deformation are greater. We just need the sealant to 'unstiff', nothing else.
^ The amateur technique mind you
Not a Pro, will never be. Love learning new tricks that's all. God bess those who are allowed to oven their headlights... 12~15min and boom|done (way too easy in fact).
