Old 07-25-2006, 09:59 AM   #1
deliriousga's Avatar
How do you test the DME for problems?
I'm at my wits' end with trying to figure out the throttle problem so I'm wondering if the DME itself is messing up. Is there a way for me to test it or do I have to give up and go to a dealer?
I think I've done everything else I can to try and remedy the problem. The E-Gas throttle will not go over 2K rpm and gives me the code P1502. If I clear the code, the car runs beautifully until you turn off the engine and restart it. That's the case whether the engine is cold, warm or hot. I have checked for vacuum leaks and replaced the MAF, O2 sensors, fuel pump relay and throttle body. I don't know what else could cause this problem and go away when the code is cleared unless it's a problem with the DME.
TIA!
1966 Wife White/Brown Top
