I had a similar problem on a e-gas VW. The DME wouldn't complete the throttle body adaptation cycle. I removed the gas pedal assembly and took it apart. Inside it's just a big potentiometer, used some contact cleaner on it, reassembled and it worked fine again. You might want to give this a try, you can also remove the cover on the throttlebody pot and clean it in the same manner.
