08-31-2017, 03:11 PM
03 Dipstick Hard to insert
I had my engine changed last winter (IMS failure). While I had periodically checked the oil level with the gauge on the cluster, this last weekend I decided to check the dipstick. The dipstick, which used to slide right in with just a little jiggling, now was very hard to insert. Multiple tries and needing to almost force it in.
I'm wondering if the plastic tubes that connect the trunk opening to the engine could not be properly connected or broken.
Would checking this be visible from the engine opening reached by putting the top in the service position? If not how do I inspect it?
Thanks, Carlos
2003 Boxster S Tiptronic
08-31-2017, 03:37 PM
Artist, 986S tinkerer
I will not be tempted...
I will refrain from juvenile comments...
Yes, you can follow the tube down to the block. Is it hard to insert or is it when you've got it halfway in? ... Seriously.
08-31-2017, 04:09 PM
Ha, I wrote my suggestion and erased for the same reason...
08-31-2017, 04:21 PM
This is the first time I have used the dipstick since the engine was swapped. The gauge on my cluster shows oil as FULL but the dipstick came out dry. Leading to my suspicion that it wasn't actually making its way to the block. And you have to feed the dipstick by holding it near the opening in the trunk and pushing it inch by inch.
If I open the engine access hatch on the top of the engine will I see the dipstick tube ?
08-31-2017, 06:09 PM
Yes. The reason for my question was because you may not see the vey first part behind the firewall, but you can see the rest of the tube going down to the block. You may need an inspection mirror and a good light.
09-01-2017, 04:41 AM
The dipstick tubes can crack . The dipstick can pop out of the tube and not go into the engine. Easy fix. I replaced mine. Woody probably has one.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
09-01-2017, 05:03 AM
FYI, I've heard of the dipstick making contact with a positive cable on the back of the starter and creating a short. I have one car that had an engine fire that i believe was created by the dipstick
Woody
09-01-2017, 05:16 AM
Thanks all I will check this weekend. Woody - thanks for alerting me to the fire risk - that definitely got my attention
Is there a DIY on replacing these parts, is it obvious what you need to do, and if I need to replace parts will I need special tools (I'm familiar with how tight working space can be)
09-01-2017, 05:17 AM
It starts normally but gets sticky about half way in. That's when you need to force it in
09-01-2017, 05:25 AM
You maybe will need a pair of pliers for the tabs up top, but the bottom has a push button release. The bottom can be difficult to reach and release sometimes. I sell the dipstick and tube for $15+shipping
Woody
09-01-2017, 06:01 AM
Thx Woody. Piece of mind dictates that I open it up this weekend and take a look
09-03-2017, 06:06 AM
That was me. And yes it did happen.Luckily it didn`t short.
99 Boxster sold
88 944S sold
71 Opel GT sold
09-03-2017, 03:25 PM
A long time Porsche Mechanic warned me (a noob) to also be careful when inserting and removing the dipstick so as to not break off the plastic at the end. That's not a good thing to have loose in the engine. Just thought I'd pass that along.
09-07-2017, 01:53 PM
Finally had a chance to go in the engine compartment and have a look. I think I found the tube the dipstick slides into, and not only could I not see that the dipstick had pierced it, but I felt it closely and didn't find any problems. It's a hard tube that transitions to rubber near where it exits the engine, right?
And I had forgotten what a joy it was to open that compartment and then put it all back again, especially as I have the Bose speaker on the read shelf. Glad I didn't have to replace anything -- that space is tight
My only remaining question is that my gauge in the cluster reads a little over full (ihad recently added a quart) and the dipstick is barely showing any oil. Which one should I believe?
