Old 08-30-2017, 04:52 PM   #1
Turn signals not working
After hooking up my tire trailer I found my turn signals didn't work. Checked fuses and replaced flasher. Hazards work. A local shop agreed with me it must be the turn signal switch. They sold me a supposedly good used one. However after installation, still no turn signals. Is there any procedure to troubleshoot the pins on the back? Any other possibiliities? It's a 2000 Boxster. Thanks.
nohops is offline   Reply With Quote
Old 08-31-2017, 02:22 PM   #2
Artist, 986S tinkerer
NewArt's Avatar
Both front and back? Indicator on dash?
Old 08-31-2017, 03:17 PM   #3
When was the last time you changed your:
Any other odd electrical gremlins of late (hazards are a separate 'circuit' than turn and work independently from ignition switch.)
PS - Find another errrrr a reliable shop who will diagnose the problem and not just have you throw $ at parts recklessly...
"Cool Prius!"
- Nobody
Old 08-31-2017, 05:40 PM   #4
turn signals not working
It's all the lights. No indicator on the dash. Hazards work as there should. No other electrical gremlins. I talked to a mechanic who felt it was the hazard switch, even though the hazards work. I will explore that option. BTW if you don't have a T30 torx to remove the airbag, a 3/16s straight blade screwdriver will work.
