Old 07-10-2006, 03:03 AM   #1
Send a message via AIM to blinkwatt
Problem with Rear Spoiler Switch...
I installed the rear spoiler switch with no problem,followed the instructions and thought everything was fine. I hoped in the car today when it was dark and I noticed something. The key wasnt even in the ignition and the rear spoiler and door lock switch were illuminited!?!? Is this normal? I used the brown wire from the door lock switch for the spoiler switch harness,could that have had something to do with it?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 07-10-2006, 05:12 AM   #2
definitely had something to do with it. not sure which color wire is what, but you need to use a wire that's only hot when the ignition is on.
you've tapped into the door lock circuit for power; the door locks work wether the key is in or not.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
Old 07-10-2006, 08:22 PM   #3
Hi,
The Brown wire in Boxsters is almost always a Ground. You should ground this wire to one of several ground points under the Dash. This will cure your ills. Hope this helps...
Happy Motoring!... Jim'99
Old 07-11-2006, 01:30 AM   #4
Originally Posted by MNBoxster
Hi,
Do you happen to have a diagram or picture of where they can be found?
Old 07-11-2006, 04:25 PM   #5
Hi,
Here you go...
