Old 06-07-2018, 08:15 PM   #101
Old 06-18-2018, 08:37 AM   #102
redciv1's Avatar
Email sent
redciv1 is offline   Reply With Quote
Old 06-20-2018, 07:24 AM   #103
Old 07-01-2018, 12:19 PM   #104
Emailed...
2002 Boxster S 7/2017 totaled (rear-ended) 11/2019
2013 Boxster S 12/2019
Pepik is offline   Reply With Quote
Old 07-11-2018, 11:50 AM   #105
Old 07-11-2018, 12:23 PM   #106
Who's askin'?
maytag's Avatar
If you've received a circuit from me and either haven't installed it yet or are having issues, please email me and I'll send a set of revised instructions (particlewave1@gmail.com).
There has been some confusion regarding the wiring and the revised instructions clarify this.
I have not yet installed mine (too many projects! ). But the instructions seemed pretty good?!?!
Old 07-11-2018, 12:33 PM   #107
Old 01-29-2019, 07:40 PM   #108
Any chance these are still available?
Jibbster is offline   Reply With Quote
Old 01-29-2019, 08:26 PM   #109
Old 03-19-2019, 05:37 PM   #110
997 SAI Repair
If you've sent an email, I just responded. If not, email me at particlewave1@gmail.com.
Wondering if you still have any of these available?
I have emailed you as well.
colmfmurphy is offline   Reply With Quote
Old 03-21-2019, 01:09 PM   #111
The problem is that a couple people have tapped the wrong power wire. The new instructions make clear which wire to tap.
I sent Charles some supplementary Instructions-for-Dummies like me :-)
This was based on my recent experience installing a Tester.So if you are as dim-witted as me, you might ask him about that in case it would help you.
One point to remember is that although the SAI based code and CEL should disappear when the Tester is installed correctly, if you still have a "Secondary Air Not Ready " that may remain. That "Not Ready" on the Readiness Monitor will cause you to fail the Smog Test in States that use the California style test. The way to fix that is the infamous and vague 'Drive Cycle'.
In States with a visual exam, do not remove the SAI pump - you will certainly fail and may get an 'equipment tampering' flag which means going to the Referee. Not good ! So maybe leave the pump in place and just disconnect the connector on the SAI pump.
Durametric (or similar) will show you the Not Ready status.
Check your work with Durametric. Watch the O2 sensor voltages while the SAI pump is running for both banks,pre&post cat. If one side is dead, check your O2 sensor wires at the new Tester.Tug them gently to ensure they are secure.
If you have vacuum leak codes related to the SAI - for example the Vacuum Reservoir or the vacuum hose/connectors ,that may need to be fixed to clear the code.
This may help:
https://www.youtube.com/watch?v=go34DJAuPyg
It is a common problem on German cars with SAI in this era.Similar solutions are offered for BMW E36 for example: http://e36-electronic.com/
If you are worried about saving the planet, the SAI operates for 90 seconds max at startup and occasionally during cruise. You'll leave a massive carbon footprint by throwing parts at the problem. The rest of the world did not fit this system -just us ! Maybe when you have time,it is a fascinating dive into the bowels of the M96 to fix the SAI codes and readiness problems - see videos linked above.
Old 03-21-2019, 01:16 PM   #112
WillH's Avatar
Originally Posted by WillH View Post
How are the O2 code fixers coming along?
:dance::dance::dance:
Old 03-23-2019, 05:38 AM   #113
Xpit77's Avatar
I haven`t installed mine yet. Is there an upgraded install instructions?
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 09-06-2019, 01:25 PM   #114
Old 09-09-2019, 11:27 AM   #115
Old 09-12-2019, 03:47 PM   #116
And then there was one...
Old 09-15-2019, 04:13 AM   #117
1998 Boxster Silver/Red
Got mine. Thank you.
Wife, seeing small unopened box upon the counter, in smarmy delivery, "What's that? Bumper cover? Exhaust system? Hard top"?
Me, "Insurance".
1998 Porsche Boxster
Old 09-15-2019, 05:12 AM   #118
There Is No Substitute.
rick3000's Avatar
Me, "Insurance".
Haha! That's why I bought one, and since my 986 threw a SAI code yesterday, I'm glad to have the extra "insurance."
Old 09-15-2019, 12:22 PM   #119
B u m m e r! Is it a clode you can resolve through investigation? Or. are you going to have to install the part?
Old 09-15-2019, 02:09 PM   #120
rick3000's Avatar
B u m m e r! Is it a code you can resolve through investigation? Or. are you going to have to install the part?
It was P0410 and P1411 which I have had pop up 2-3 times over the the last several years. Normally unless it's a serious code, I will wipe it and see it comes back and monitor for other issues/symptoms to try and narrow down what may be the problem. So far it hasn't come back, but if it does I will probably fix it. I just like having the option to delete the secondary air system since it can be expensive and tough to troubleshoot.
