Old 09-15-2019, 03:09 PM   #120
rick3000
There Is No Substitute.
rick3000's Avatar
B u m m e r! Is it a code you can resolve through investigation? Or. are you going to have to install the part?
It was P0410 and P1411 which I have had pop up 2-3 times over the the last several years. Normally unless it's a serious code, I will wipe it and see it comes back and monitor for other issues/symptoms to try and narrow down what may be the problem. So far it hasn't come back, but if it does I will probably fix it. I just like having the option to delete the secondary air system since it can be expensive and tough to troubleshoot.
