Old 06-21-2006, 02:53 PM   #1
Help Please - Leak in Cockpit
When I have the airconditioner on there is a big leak over the pedals. It seems to only leak when I press the clutch in though. I thought it might be just a hose above the pedals but I was unable to locate it on my first look.
99Boxster is offline   Reply With Quote
Old 06-21-2006, 04:20 PM   #2
Hi,
Your AC Drain is clogged. You'll need to get under the Car and find the drain tube (it is in the Mid-Left Center) and carefully use a piece of wire to clear it. Don't get your face right in it or you may get a faceful of swamp water once the clog is cleared. It's currently backed up and will flow left because the car will lean slightly left with only the weight of the driver. Hope this helps...
Happy Motoring!... Jim'99
Old 06-21-2006, 05:34 PM   #3
Damn! You've got to be right on because when somebody is in the passenger seat (and only when somebody is in the passenger seat) it leaks on that side also. Thanks for the quick response! I'll take a look at it this weekend. Since I generally keep the top down and the ac off it is not that big a deal right now.
