Hi,
Your AC Drain is clogged. You'll need to get under the Car and find the drain tube (it is in the Mid-Left Center) and carefully use a piece of wire to clear it. Don't get your face right in it or you may get a faceful of swamp water once the clog is cleared. It's currently backed up and will flow left because the car will lean slightly left with only the weight of the driver. Hope this helps...
Happy Motoring!... Jim'99
