Old 02-05-2017, 12:47 PM   #1
Does the Brey Krause roll bar extension interfere with the top service mode ?
I bought a Brey Krause roll bar extension last year from a forum member and have not installed it yet . I had the top in the service mode recently to remove/replace the MAF sensor and I also have an aftermarket soft top with the glass rear window.
When I put my car in service mode I fold the glass window so it resides partially over the roll hoops . If the BK extension was installed there is no way I could do that .
So for those of you that have the BK and a glass rear window can you still access the engine enough to do the routine stuff ?
rfuerst911sc is offline   Reply With Quote
Old 02-05-2017, 01:14 PM   #2
steved0x's Avatar
I have the bk bar but a soft plastic rear window, if you have an aftermarket glass rear windiw it I the small one, right? The bk bar sits forward of the hoops by a tiny bit, maybe there will be enough room?
A quick way to test would be take the two ends of the bk bar off (it is,easier to install with these off and you have to take at least one off to install) and then test fit it onto the hoops, and then place the top in service mode.
I can lower my top and take some pics, I need to get in there and check my Ps fluid anyway before my next event.
Old 02-05-2017, 01:49 PM   #3
I did not realize the BK bar sits a little forward of the OEM hoops . If that is the case it will probably work just fine . I guess I should go ahead and install the darn thing ! Thanks for the quick reply.
Old 02-05-2017, 02:36 PM   #4
Artist, 986S tinkerer
NewArt's Avatar
Anyway, the bar comes on and off in 10 minutes or so. So it's not really a problem.
Old 02-05-2017, 03:48 PM   #5
That is a great point thanks !
Old 02-05-2017, 08:32 PM   #6
I had the BK bar with my glass window top and it will require holding the glass back against the roll bar (it will want to fall down towards the engine compartment). I used some clips to hold it back. Nothing to really worry about, you'll figure it out in about 20 secs.
