Old 01-24-2017, 06:21 PM   #21
^ Tidy. Nice pics also. thx!
You're welcome. I expect a full mock-up of a better design in the morning.
Perhaps something where the magnet/phone could be positioned not to block any controls, and as little of the vents as possible. Maybe something like this:
tomonomics is offline   Reply With Quote
Old 01-24-2017, 06:28 PM   #22
Nine8Six's Avatar
Nope, doesn't work (for me anyway). Just like you've setup in yours is perfection imo. Small magnet, not invading, out of the way, etc... love the idea
Old 01-25-2017, 12:25 AM   #23
geraintthomas's Avatar
Or just get this:
Slots into the CD bay. That's what I'll be getting soon - seen it in the skin on a few other Boxsters and the positioning is perfect.
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
Old 01-25-2017, 12:33 AM   #24
heliguy's Avatar
You don't need one, you already have a carphone.
Old 01-25-2017, 04:11 AM   #25
lol....I saw that after I posted. And there's a GPS too!!!
Old 01-25-2017, 07:43 AM   #26
I wish my car wasn't in storage as there is no way I can describe this without pics...
probably the most useless post of 2017 so far
I made a small metal Z shaped/shelf-like bracket out of sheet metal that slides in between the upper and lower console (the space below the radio) and I can set my phone on it horizontally. Perfect for using my phone's nav.
When I don't need it, I put it in the center console compartment. I'll try to snap a pic this weekend if I can get to the car.
Vince
m332is is offline   Reply With Quote
Old 01-25-2017, 08:06 AM   #27
I'm having a problem also mounting my phone on the dash 2003 S, any suggestions?
fanguy is offline   Reply With Quote
Old 01-25-2017, 08:14 AM   #28
BirdDog's Avatar
Sorry fanguy... the Motorola Dynatac 6000X is no longer supported for use in a Boxster!
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
Old 01-25-2017, 10:56 AM   #29
There Is No Substitute.
rick3000's Avatar
I recently installed this mount from ProClip. It was $55 for the mount and cradle on sale. That is an iPhone 7+ in the picture, and it does not interfere with any of the controls, or shifting, and I really like the location. It is easy to see and use, but not in my face or drawing too much attention to itself.
I bought a spare trim piece to clip it onto, because it clams on very tightly to the leatherette side console trim. If I where to do it again I might use a generic RAM mount and bolt it directly into a spare leatherette side trim piece instead of using the clip on mount.
Old 01-26-2017, 08:21 PM   #30
Storage bin with speaker off. That removes all temptation to do anything but drive. I have a separate windshield-mount Garmin for navigation when I need it.
DBear
dbear61 is offline   Reply With Quote
Old 01-27-2017, 04:58 AM   #31
Originally Posted by dbear61 View Post
...I have a separate windshield-mount Garmin for navigation when I need it....
Good for you putting phone away. Hopefully you're prudent placing the GPS...
[rant]
Too many times I see idiot drivers w/ GPS planted smack dab in middle of their field of vision... cord loosely draped down to boot. So not only now is vision blocked but cords can also easily get tangled in steering wheel or control stocks.
Sometimes people are their own punishment...
[/rant]
"Cool Prius!"
- Nobody
Old 01-27-2017, 08:17 AM   #32
Fintro11's Avatar
I stole this from my 944, it has detachable mounts for gps or phones. It is a bar of aluminum so you can bend it to any posistion you need.
It comes with hardware to attack to the seat mounting frame.
Thinking of getting a window mount so I can use it as a track recorder.
Old 01-28-2017, 03:10 AM   #33
"50 Years of 550 Spyder"
10/10ths's Avatar
I have this....
Car or Truck Seat Rail Bolt or Floor Mount with 22" Gooseneck: Arkon.com
And I LOVE it!
It allows you to place the phone exactly where you want it, it's not in the way, and it will hold any size phone.
I can easily see my moving map display, calls, music, etc.
Easy to install, functions beautifully.
You're welcome.
Old 01-28-2017, 06:15 AM   #34
Here is another alternative. Not for a phone but can be modified to work. I was looking for a way to mount my Bluetooth Transmitter. I could have used the power outlet/cigarette lighter but it was battery powered and it wasn't very secure. I wanted an ignition power so I wouldn't have to remove the transmitter with the car not running.
I purchased a power outlet and wired it to the phone connector which is ignition powered. I was debating whether to mount the power outlet in the side panel but that involved drilling. I was looking for a less intrusive method being once drilled, the only reversal is purchasing the side panel. I happened to find this lying around the house. It is a bookend bracket.
This bracket just happened to fit/slide in between the upper console and dash. It was sturdy and secure and removable.
I just bent the bracket to fit and zipped tied the power outlet to the bracket. Kinda hacked but works and looks good from the front.
Miles1 is offline   Reply With Quote
Old 01-28-2017, 01:14 PM   #35
lkchris's Avatar
Kuda mount in mine ... with 5S holder
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 01-28-2017, 06:07 PM   #36
pics deleted and reposted in next post...
Old 01-28-2017, 06:12 PM   #37
Hopefully these are right-side up. I started with a door latch protector I bought from Home Depot. I cut one end down, bent it and painted it black. I set my phone on it when I want to use the navigation function. Other than that is sits in the center console when not in use.
It actually just blends in when the phone is one it (usually laying horizontally)
Old 06-14-2018, 06:54 AM   #38
On the windshield with this:
https://www.amazon.com/gp/product/B01780KZMW/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
Shasta_McNasty is offline   Reply With Quote
Old 06-14-2018, 09:01 AM   #39
Cunningr's Avatar
I bought the mount from rennline. Mounts on the right side of the console, a little pricey for what it is, but works awsome keeps phone out of window. I cant use a window mount here because it is illegal anyway.
Old 06-14-2018, 11:36 AM   #40
I bought the Rennline as well but hated the way it fit and that the shifter blocked most of the GPS when in fifth gear. So I moved it.
garym is offline   Reply With Quote
