Old 01-22-2017, 04:30 PM   #1
Transmission Fill Plug
Anyone have any advice about how to remove the transmission fill plug on a 2000 2.7 5-speed? I have a 17mm hex key and a 17mm hex socket. The fill plug is partially stripped (rounded edges) and I cannot break it loose. I cannot break it loose with arm strength or a hammer.
I know I will require a new fill plug, but what are my options for removal? Should I keep trying to remove it and risk further stripping the plug? Would it be better to admit defeat and have a mechanic remove the plug? If I have the mechanic remove the plug, should I have them do the whole job or just remove the fill plug?
I bought the car from a Lexus dealership a few months ago and the car went through a multi-point inspection, but with the plug being partially stripped and frozen in place I don't think they checked it. I'm not sure if the fluid was ever changed and first and second are hard to shift into when cold.
Alex
alex.rhodes is offline   Reply With Quote
Old 01-22-2017, 05:01 PM   #2
Please put the hammer away and order some Kroil from Kano Labs.
Penetrating-Lubricating Oils
Use a little every day(the Boxster not you!) and tap the plug before use to try to loosen up the corrosion.Be patient.
Old 01-22-2017, 06:35 PM   #3
Use WD-40, PB Blaster, or similar and let it sit for a day.
Then try again. Use a long handle on the hex socket to get good, solid leverage.
If still no joy, I'd throw a little heat onto it with a propane torch. Of course, you need to be careful, but a little localized heating (not glowing red!) of the plug shouldn't be too risky. its amazing what a little heat will do to loosen up a fastener.
Old 01-22-2017, 06:59 PM   #4
One other thing you can do. Tighten it a little. If it moves, its ready to be removed.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
Old 01-22-2017, 07:26 PM   #5
Pdwight's Avatar
It's been changed
Otherwise it wouldn't be this way. I changed my 6S fluid at 75K and now mine is sluggish changing until I get a mile or two down the road (especially in cold weather). Keep at it and good luck....Kroil is wonderful stuff
