Old 01-22-2017, 05:30 PM   #1
alex.rhodes
Transmission Fill Plug
Anyone have any advice about how to remove the transmission fill plug on a 2000 2.7 5-speed? I have a 17mm hex key and a 17mm hex socket. The fill plug is partially stripped (rounded edges) and I cannot break it loose. I cannot break it loose with arm strength or a hammer.
I know I will require a new fill plug, but what are my options for removal? Should I keep trying to remove it and risk further stripping the plug? Would it be better to admit defeat and have a mechanic remove the plug? If I have the mechanic remove the plug, should I have them do the whole job or just remove the fill plug?
I bought the car from a Lexus dealership a few months ago and the car went through a multi-point inspection, but with the plug being partially stripped and frozen in place I don't think they checked it. I'm not sure if the fluid was ever changed and first and second are hard to shift into when cold.
Alex
alex.rhodes is offline   Reply With Quote
