Old 12-31-2016, 02:54 PM   #1
This is actually a great idea if you need the height of a lift. Very stable. The next problem would be a jack that can lift high enough.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
Old 01-01-2017, 09:08 AM   #2
There Is No Substitute.
rick3000's Avatar
Originally Posted by BoomerRoadie View Post
I'm starting to recognize a pattern with you guys. Every time I ask a question and give you a choice between Option A and Option B....I end up with both!!!
Haha, there are no simple answers, and you have to keep in mind most of the people on this forum are enthusiasts not mechanics so you will need to evaluate the information/opinions you get for yourself and determine what you think is the best/right way to do things. That said, there are a lot of super knowledgeable people on this forum!
Those Lift Bars look great, but they are model specific and $275 shipped, a bit pricey in my opinion. The problem with that Harbor Freight attempt at a lift bar is that it doesn't have a place to put the jack stands once you get the car into the air, since the bar is already using/covering the jack points.
+1 for the Harbor Freight Long/Low Jack Gelbster mentioned. That is what I use and it works great, and can reach the back of the engine cover/plate to lift both rear wheels at once.
My Esco stands have a minimum height of 13", which is doable, but getting the car onto the stands is somewhat terrifying. I think 15" minimum height is too high, without using a crib or some cut up 2x10" to get the car a bit higher when you start. I will be building a 2 or 3 stage wooden crib in 4" high sections before my next oil change.
Old 01-01-2017, 12:45 PM   #3
If you saw the lift bars, you would understand why they are worth the money; they are incredibly well made and very strong. A car up on them is both high and very stable, even at heights above 20 inches. We have a couple of sets and used them both in the shop and at the track. I would highly recommend them to anyone working on jack stands.
Old 01-01-2017, 03:15 PM   #4
I can't even remember what this post was about, but this cross beam thin from HF g is interesting.
I remember reading someone posted that when the HF ones are used you cannot inset the jack stands in position because the cross bar occupies the space you need to properly place them.
Is this true?
Is there another way around this problem?
Thx!!
BoomerRoadie is offline   Reply With Quote
Old 12-31-2016, 08:50 PM   #5
A "long" floor jack will work - it lifts 2 feet !
Low Profile Floor Jack - 2 Ton, Rapid Pump® Jack
I use 2 at once - pump up both together.Place jack stands. Go around the other side ,rinse and repeat. Or do it front/rear.
But just get a 2 post lift and bypass all this equipment. Wonderful to have comfortable access !
Old 01-02-2017, 02:46 AM   #6
husker boxster's Avatar
My question for you guys is, will a 15" minimum height be a problem when used with the Boxster?
Sure, they'll work but it's a matter of how much effort you want to put into it.
You're dealing with compromises. Chances are a jack that will fit under your Box may not have enough lift to clear 15" stands. So you have to lift twice. Or you drive onto some blocks before lifting to give you enough clearance for a larger jack to fit under the car.
My jack requires 5" of clearance and it barely fits under my PASM CSS. My JackPoint jack stands require 12" (probably 13 to get the cap lip to clear the stand) and it takes all the lift of my jack to get it to work. Going another 3-4" would take a lot of lift.
If you don't mind the time and effort of lifting twice, then buy the 15s. Otherwise, spring to a set for ea vehicle and save yourself lots of unnecessary effort down the road. Buy a set for the Box and it will be the best $40 you'll ever spend.
1989 928 S4 5 spd - black
Old 01-02-2017, 05:55 PM   #7
husker boxster,
I'm not sure if I totally follow you. It sounds like you are saying that 15" jack stands will require longer amounts of time and extra steps, whereas the 10" 2-ton jack stands will not.
Presumably this is a function of the garage lift and the range it offers. I'm not sure I understand why it will take longer to jack the car up to a 15" height. I mean I get it, it's 5 inches higher, but does that require additional step?
The jack I am going to buy tomorrow is the Daytona one from HF. That has a range from around 3" to a little over 20". Can you not just jack the car up to the 15" minimum height of the 6-ton jack stand?
Old 01-02-2017, 06:51 PM   #8
If you jack will cover the 15", then it won't take extra time. Mine does not go that high.
Old 01-02-2017, 07:17 PM   #9
Ok. Thank you. Now I follow you. Thanks for getting back to me so quick too!!
Old 01-05-2017, 10:58 AM   #10
On the slippery slope
JayG's Avatar
That might be wide enough to reach between the rear suspension points and lift the back evenly.
I raise from one of these points and it pretty much raises the entire rear. One side is a couple of inches lower
2004 996 Targa Tip
Instructor - San Diego region
Old 01-05-2017, 11:15 AM   #11
jeeper31's Avatar
And what about the front. I need to get the car up on 4 stands.
jeeper31 is offline   Reply With Quote
Old 01-05-2017, 11:49 AM   #12
I would not do that. I have seen crushed panels from lifting away from the jack points. The plates are wide, so it may work, but I would not take the chance.
1941 Dodge Luxury Liner Coupe
Old 01-05-2017, 12:45 PM   #13
JayG's Avatar
see post above ^^^^ for safe rear point
or check out
Jacking Up and Lifting the Porsche Boxster on Jack Stands | 986 / 987 (1997-08) | Pelican Parts Technical Article
2004 996 Targa Tip
Old 01-05-2017, 12:41 PM   #14
JayG's Avatar
What I do is use the rear side lifting point and it will raise the entire side
Put a jack stand at the front point
Repeat for the other sire and now the front is up
Then raise the rear and put stands at both rear points
or get lift bars and you can raise 1 side at a time and put stands on each side
Pic from Pelican for rear alternate lifting point
2004 996 Targa Tip
Old 01-05-2017, 01:02 PM   #15
I am going to do my own lift bar. 2" square steel tube 3/8" thick with bolts at the ends whose heads fit into the jack point recesses. Should cost less than $100 for two. McMaster to the rescue.
Old 01-05-2017, 01:20 PM   #16
McMaster is expensive ! Your local steel yard has all this.
The bolts If you measure the socket in the jacking point ,you'll realize a bolt head is a tedious shape to use.
I made some using flange head nuts and a bolt -upside down to what you propose. The leading threads of the protruding bolt shank act as a primary guide into the lift point socket Then 1/4" behind comes the nut.The nut almost fills the socket width. The flange shoulders actually rest on the face of the jacking point. A structural steel H.D. washer may help. Be careful it is not the tip of the bolt that supports the car ! You want the weight on the flange & /or the structural steel H.D. washer
Bolt Depot !
Old 01-05-2017, 01:24 PM   #17
Thanks. Makes sense. Will look for steel yards around here.
