Old 06-15-2006, 07:05 AM   #1
Mike - thanks for that suggestion - I might look into achieving the bracing with a thin clear plastic rod along the top of the rear screen.
Adam - any link you can dig up would be most appreciated.
Thanks again,
James
jamesatfish is offline   Reply With Quote
Old 06-15-2006, 10:51 AM   #2
Or if there was a way to do the chop from the inside, which I guess would be more a karate pull rather than a chop. I had though about taping some fishing line to the middle part of the window where I have to chop it and then just pull on it while I open the top. Aside from it possible looking kinda crappy/hooptie, it might just work. I'm interested in that bracing thingy as well.
I think part of it too is plastic loses elasticity over time, sun, elements, etc.
thanks,
Larez2
larez2 is offline   Reply With Quote
Old 01-08-2007, 12:59 PM   #3
Be careful karate chopping the top. I once chopped right through a plastic Miata windw. Just take it easy when you do it.
oversteerdawg is offline   Reply With Quote
Old 01-08-2007, 01:35 PM   #4
boggtown
Guest
Posts: n/a
All youd need if you wanted to do it from the inside is a suction cup. Im pretty sure thatd be an easy way. Plus you could keep it inside the storage box so no one would know.
Old 01-09-2007, 08:49 AM   #5
I have never understood this. When the car was new and being shown at the dealer I doubt the car had this flaw (or did it). Seems hard to believe that Porsche would have distributed this knowing you had to jump out and chop the window. It is the most annoying thing on an otherwise great car.
2000 Black Boxster S
EVO Intake & GIAC Tuning
Headers & Porsche Sport Exhaust System
ROW M030 Suspension
Front & Rear Strut Braces
B&M Short Shift & EVO Billet Linkage
steve00s is offline   Reply With Quote
Old 01-09-2007, 08:52 AM   #6
Maybe an "admin" can create a "top" section on the board to consolidate all the information/threads.. just a thought...
2000 Boxster 2.7 (sold)
1978 911 SC (sold)
1970 914 w/2056 (sold)
racer_d is offline   Reply With Quote
Old 01-09-2007, 11:02 AM   #7
I think the issue is that the rear plastic window is just that. PLASTIC. It will behave differently in different climates and conditions.
Most everyone here is aware that often times a 'chop' is a good thing to do to get the window to fold correctly, especially at lower temperatures. Makes sense, as plastic will become more firm when it's cool, and vice, will become more flexible when it's warm.
I think the best thing one can do is be cautious, observe the window's flex when opening the top. Keep the window clean, and avoid exposure to chemicals. Use a reputable product to clean and condition it, and it should last a long time.
The alternate solution is to replace the top with a glass rear window top. Remember that your top WILL wear out. One CAN get a LONG service life out of it if it's well cared for, but eventually, it will likely have to be replaced.
FrayAdjacent is offline   Reply With Quote
