Old 09-11-2016, 10:15 AM   #11
911monty's Avatar
Thanks Markus I was trying to be optimistic that's why I said hopefully! I think there needs to be a sticky somewhere on the steps to take after an AOS failure, I modified your steps as a first attempt. Hope you don't mind
What to do: Do Not attempt to start the engine until all steps below have been completed as serious damage to the engine can result!
1. steps to take after AOS failure.
  • If you have a Durametric or any other diagnostic tool note all error codes and check their meaning.
  • Pull all spark plugs and clean them. There might me oil and crust on them. Check the electrode distance.
  • Remove Fuel pump relay.
  • Turn over the engine while the spark plugs are out. Aprox. 2 times for 5 seconds. Check if oil is coming out of the spark plug hole and how much.
  • Put in all sparks plugs.
  • Remove the MAF and clean it.
  • Remove as much of the air intake system after AOS and MAF and clean it. There will be lots of oil in it.
  • Install fuel pump relay. Start the engine.
  • If it runs without unususal noises or anything else – OK.
  • Do a test drive.
  • If you have a Durametric or any other diagnostic tool check error codes.
  • If you don't have codes or anything else – repair done.
