Old 07-18-2016, 06:11 AM   #1
Ignition switch starting to fail?
Hey all,
I have a '99 boxster base. Turned my windshield wipers on yesterday and nothing! Pulled over and messed about, finally discovered that they'll turn on ok if the key isn't rotated all the way over. So, I'm starting the car normally, then rotating the key a little counter-clockwise and the wipers will turn on. I remember reading about boxsters having a faulty ignition switch (Link below). Am I right in thinking it's just the switch? Sounds like a plastic part replacement, is this difficult? And on that page that I linked to below, the guy says people get the part from autozone or the Audi parts counter, is this a standard part that fits many cars?
From BoxsterInfo, scroll down a little for the paragraph on the ig. switch issue.
Mauiguy is offline   Reply With Quote
Old 07-18-2016, 08:01 AM   #2
kjc2050's Avatar
Do a search. Tons of posts on this topic. Here's my story on this topic. Read the entire thread: http://986forum.com/forums/general-discussions/46411-ignition-switch-replacement-holy-crap.html
Old 07-18-2016, 08:19 AM   #3
Nine8Six's Avatar
Judging from this alone I'd say 90% chance it is indeed caused by a faulty the ign switch. Too well known of a problem, although the wiper fault is a first for me. Never heard before.
Wait for the "pro" to comment before making any decision.
Old 07-18-2016, 08:26 AM   #4
Parts are cheap and the fix is easy, if you're a contortionist.
It involves going up under the dash and replacing the ignition switch. I got mine from Napa for around $15. Remove the plug, and two small set screws hold the switch in place. They're the trickiest part. If you don't have a jeweler's screwdriver set, you'll need one with a small standard screwdriver.
With out the key returning all the way back to run after starting, headlights and wipers are disabled. Parking lights, however, will function. A simple counter-clockwise light turn of the key enables them. If that is your symptom, a new switch is the fix.
JTapper is offline   Reply With Quote
Old 07-18-2016, 08:46 AM   #5
Just had this very problem this weekend. For me the A/C and wipers didn't work unless I nudged the key back from the normal run position. I ordered a part from Pelican listed as OEM for $27, but whether that supplier provided that part to Porsche I couldn't tell you. Just relieved that I didn't have to buy a new AC system
CB
'03 Boxster S
Cbonilla is offline   Reply With Quote
Old 07-18-2016, 09:28 AM   #6
Ok I'm 5'9" and hopefully flexible enough to do the fix. I can also try fixing via the dashboard route noted in kjc2050's thread. If I go that way I can get that nifty screwdriver set with flexible extension since I'm literally down the street from Harbor Freight tools in Braintree, Mass. It sounds like it's a much quicker fix when done from underneath, as long as I can do the physical part so I'll try that way first.
Old 07-18-2016, 10:04 AM   #7
kjc2050's Avatar
Yup. If I had to do it again, I'd go that route. I purchased that screwdriver set from HF with this in mind. Good luck.
Old 07-18-2016, 10:51 AM   #8
K I'm gonna buy 2 ignition switches since they're so cheap and it seems like I'll need another one eventually. The one from kjc2050's thread isn't available from that seller anymore so I looked around and found one in Tennessee:
http://www.ebay.com/itm/Meyle-Brand-Ignition-Switch-A4-A6-A8-S4-S6-80-90-100-Porsche-911-Boxster-/151437045342?fits=Year%3A1999%7CMake%3APorsche%7CM odel%3ABoxster&hash=item234259ee5e:g:5BkAAOSwUuFWvbWZ&vxp=mtr
so if anyone knows if it's a bad seller or the wrong part, do let me know!
Old 07-18-2016, 12:06 PM   #9
$12 shipped with prime on Amazing.
Old 07-19-2016, 06:09 AM   #10
Xpit77's Avatar
Remove the AC vent . It`s not that easy to get in there. Flex driver is perfect. I bought the switch from VW dealer.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 07-22-2016, 12:35 AM   #11
Same, I got it from VW. eBay seems like a less permanent fix with parts of unknown origin.
I'm 6'1" and had little trouble getting access from below.
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
Old 07-22-2016, 05:35 AM   #12
I ordered two the other day and tracking says they'll arrive between today and the 25th so once they do I'll pop one in (Spoken like I've done it a thousand times and it'll be easy). I've only seen a pic or two that illustrate what to do so I'll take some pics and make a tutorial, with all my mistakes edited out.
Old 07-22-2016, 05:37 AM   #13
Of course!
Old 07-22-2016, 08:12 AM   #14
Xpit77's Avatar
shhh
Ok. Everyone who has done this don`t say a word.
Let`s wait for the finished it post. Wink wink.
99 Boxster sold
88 944S sold
71 Opel GT sold
Old 07-22-2016, 10:20 AM   #15
I'm embarrassed to say I couldn't get the HVAC vent out so I just went in from below.
Old 07-29-2016, 05:42 PM   #16
Ok, I finished it, all set! It was wikkid hard to do it from underneath but using a small screwdriver I was able to scrape away the loctite then loosen the screws. I didn't pull apart the bad switch but the white plastic part was definitely broken/worn down. Cheap crap, just make it out of all metal and increase the retail price by a dollar, we'll pay it.
I had given up on the underneath method and was going to try going through the left side of the dashboard but the headlight switch knob was not going to come off. I pulled very hard on it, no dice. I will look that up now because I'd still like to try it and it seems like I'll have to replace the switch again in the coming years.
Just to button up this post I want to say thanks to all who helped. I stated earlier I'd do a full pictorial but after more searching found these three threads with pics so I didn't see a need to do another one
Replace Ignition Switch :: Repairs :: Greg's 2004 Porsche 996
Porsche Boxster Ignition Switch Replacement
Replace Ignition Switch Porsche DIY
Old 07-29-2016, 05:46 PM   #17
Good work!
Old 07-30-2016, 05:01 AM   #18
Xpit77's Avatar
Buy the Bentley Service manual.
I think the white ones are original.
99 Boxster sold
88 944S sold
71 Opel GT sold
