Originally Posted by Mauiguy
Ok I'm 5'9" and hopefully flexible enough to do the fix. I can also try fixing via the dashboard route noted in kjc2050's thread. If I go that way I can get that nifty screwdriver set with flexible extension since I'm literally down the street from Harbor Freight tools in Braintree, Mass. It sounds like it's a much quicker fix when done from underneath, as long as I can do the physical part so I'll try that way first.
Yup. If I had to do it again, I'd go that route. I purchased that screwdriver set from HF with this in mind. Good luck.
