Old 07-16-2016, 02:21 PM   #1
Hi! - and what is this part
First off, hi, I'm new to the forums. I have a 2001 Boxster S that I bought last year for track use.
I've had some of the (apparently) typical failures so far:
* Burned out the power steering pump after a few track sessions. Had an additional power steering fluid cooler installed. So far so good.
* RMS started leaking. Had the IMS replaced at the same time.
* Broken shifter cable. That one was fun. Towed off track.
* 2nd gear is nigh impossible to shift into when the car is cold. Worn synchro. I typically shift 1-3 until the car is wamed up. Currently presents no issues on the track.
Anyhoo that leads me to my question. Does anybody know what this part is?
The rubber connectors snapped when I slid over a rumble strip this past weekend and I need a new one.
PorscheFlooner is offline   Reply With Quote
Old 07-16-2016, 02:23 PM   #2
Multi-Boxer Driver
Deserion's Avatar
It's a brake cooling deflector.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 07-16-2016, 02:47 PM   #3
You may want to consider upgrading to the GT-3 brake ducts for more brake cooling on the track. Very common upgrade.
Installing GT3 Brake Cooling Deflectors
Old 07-16-2016, 03:17 PM   #4
Perfect. Thanks guys. I'll definitely look into the GT-3 upgrade.
Old 07-17-2016, 08:49 PM   #5
Pdwight's Avatar
Mine is not there
My 2001 S does not have that piece ??
Old 07-17-2016, 08:54 PM   #6
I am my own mechanic....
Timco's Avatar
Nor does mine. I have fronts only.
'08 VW Touareg T-3 wife's car
