Old 07-16-2016, 02:21 PM   #1
PorscheFlooner
Hi! - and what is this part
First off, hi, I'm new to the forums. I have a 2001 Boxster S that I bought last year for track use.
I've had some of the (apparently) typical failures so far:
* Burned out the power steering pump after a few track sessions. Had an additional power steering fluid cooler installed. So far so good.
* RMS started leaking. Had the IMS replaced at the same time.
* Broken shifter cable. That one was fun. Towed off track.
* 2nd gear is nigh impossible to shift into when the car is cold. Worn synchro. I typically shift 1-3 until the car is wamed up. Currently presents no issues on the track.
Anyhoo that leads me to my question. Does anybody know what this part is?
The rubber connectors snapped when I slid over a rumble strip this past weekend and I need a new one.
PorscheFlooner is offline   Reply With Quote
