Old 07-08-2016, 03:03 PM   #1
Please don't do this
I found this on a boxster I just picked up. Luckily for the owner, they were hit from behind.
Woody
Old 07-08-2016, 03:07 PM   #2
911monty's Avatar
Is that a Takata airbag with the exploding wheel shrapnel mounted?
Old 07-08-2016, 03:16 PM   #3
Motorist & Coffee Drinker
78F350's Avatar
Hopefully he drove around with a full face helmet.
Old 07-08-2016, 03:30 PM   #4
Porsche9's Avatar
Wow, someone was not thinking. That would make a Takata airbag comparatively safe. You could end up with a really nice Porsche emblem imprint on you forehead.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 07-08-2016, 03:39 PM   #5
steved0x's Avatar
Yikes! I know somebody that could use that emblem, how much if I find some other stuff to go with it for the order?
Old 07-08-2016, 04:18 PM   #6
husker boxster's Avatar
That would leave a mark that wouldn't buff out.
1989 928 S4 5 spd - black
Old 07-08-2016, 04:25 PM   #7
jsceash's Avatar
How'd he have it attached. It's not drilled is it.
Old 07-08-2016, 05:25 PM   #8
stelan's Avatar
that is another way to get a face tatoo
stelan is offline   Reply With Quote
Old 07-08-2016, 09:22 PM   #9
Track rat
Topless's Avatar
Bullet loaded in the chamber...
Old 07-08-2016, 10:51 PM   #10
There Is No Substitute.
rick3000's Avatar
They used to sell a small enamel emblem that fit the steering wheel perfectly, but mounting anything else is very dangerous. Unless of course, you want a Porsche crest permanently imprinted on your face.
I would disconnect the battery before you attempt to pry that off.
Old 07-09-2016, 07:44 AM   #11
That's equivalent to a shotgun slug fired straight to your face.
One more thing. Are you testing to see if your fuel low warning light actually work? I think most of us wouldn't run our fuel level that low.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
Old 07-09-2016, 07:58 AM   #12
KevinH1990's Avatar
I think that is one of the cars that Woody is taking apart. It looks like it was a "toasty" day in Texas - 101 degrees.
Old 07-09-2016, 08:25 AM   #13
rick3000's Avatar
It's called doing Aerodynamic Testing, or at least that's what my dad claimed when he ran out of gas in his 944.
Old 07-09-2016, 01:39 PM   #14
Yes that's a car I was testing right before i removed the engine and transmission. That glued on emblem is out of character from the rest of the car. It had a recently replaced factory motor with only maybe 10,000 miles and brand new brakes
Woody
Old 07-09-2016, 01:50 PM   #15
Isn't that one of those thin plastic one's on a wheel center cap? or is that one metal?
geetee is offline   Reply With Quote
Old 07-10-2016, 01:17 AM   #16
madmodz's Avatar
When I painted my airbag, it had a metal emblem. I thought it was a huge liability. What is the solution? If I take it off what do I put in the indentation?
madmodz is offline   Reply With Quote
Old 07-10-2016, 08:02 AM   #17
I cut this off a blown airbag so you can see the proper way the emblem is attached. I don't think you can add one if your wheel didn't come with one.
Woody
