Old 06-25-2016, 02:50 PM   #1
Boxy_02's Avatar
P1128 & P1130 (Again)
First I did search and found some answers - tried solutions but did not help.
When the car is cold, the engine runs rough for a few minutes then smoothes out.
The p1128 and p1130 codes trigger if the car is in traffic sitting (idle) for an extended period of time.
Car still runs great!
I cleaned the MAF - no difference
I have swapped the MAF - made no difference.
Replaced AOS.
Replaced cracked dip stick tube.
Replaced both pre-cat O2 sensors.
Checked Intake connections - everything is tight.
As per my OBDII Reader, one O2 sensor reads a little higher than the rest.
Any other ideas or suggestions?
2002 Porsche Boxster Carrara White - 103,000 miles
Boxy_02 is offline   Reply With Quote
Old 06-25-2016, 04:17 PM   #2
Which o2 sensor is reading high and is it within range? If not try replacing that sensor (unless already replaced, not clear). You may also try running a bottle of chevron tech Ron through. I did this along with an o2 sensor replacement and my car hasn't popped these codes since.
Old 06-26-2016, 03:10 AM   #3
Project Addicted
jcslocum's Avatar
It's not the 02 sensors, they are reading like they should. You have a lean condition caused by false air introduced after the MAF, so not measured by the MAF. The ECU can no longer keep the mixture in range by trimming so throws a code.
1128 and 30 are the idle mixture trim code and not running at speed codes for BOTH sides of the engine. I would concentrate my looking at the center of the plenum for a cracked rubber part of loose clamp. The other thing to change is the fuel pressure regulator on the drivers side of the engine. It's a $45 part and 15 minutes to change.
Chasing these leaks can make you pull your hair out!!!
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 06-26-2016, 04:45 AM   #4
Boxy_02's Avatar
I was reading that "lean" condition on those codes only apply to 98 - 99 cars? On later cars it indicates a "rich" condition? Can anyone confirm this?
Old 06-26-2016, 06:37 AM   #5
Ever so slight a vacuum will throw these codes. Check all your hoses including AOS and slip connectors. Mine was the corrugated Aos at TB after 996 conversion.
Lapister is offline   Reply With Quote
Old 06-26-2016, 06:57 AM   #6
These codes can also come from a dirty or out of spec fuel spray from an injector. The techron can clean them and take care of that. Being that you've taken care of a lot of the primary causes for these codes, try a fuel cleaner.
Old 06-26-2016, 07:56 AM   #7
Boxy_02's Avatar
I will give the fuel cleaner a try. Is Techron what most people here are using?
Old 06-26-2016, 08:09 AM   #8
911monty's Avatar
I use the Lucas fuel system cleaner. It is also MUCH easier to get into the fuel fill flapper valve without spilling.
Old 06-26-2016, 08:42 AM   #9
Techron came with the most wide recommendations. Make sure you get the size that treats over 12 gallons.
Old 06-26-2016, 11:22 AM   #10
Vacuum leak somewhere. Check the MAF values. For the base it should show 13-15 kg/min. If its less ghan that. You have vacuum leak.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-26-2016, 12:48 PM   #11
Topless's Avatar
Agree an intake air leak is most likely. A failed MAF is also possible as the car is running lean. Clogged injectors are possible but unlikely affecting both banks.
TS guide for 2002 model 986:
DME 7.2 (2000-2002 Boxsters)
P-Code Bank RPM Range Reason Look for:
P1128 1 Idle Engine is running very lean and the fuel adaptation has
pegged its rich correction.
Intake/Exhaust system leaks; MAF not performing correctly; fuel
delivery components cannot deliver enough fuel.
P1130 2 Idle Engine is running very lean and the fuel adaptation has
P1126 1 Lower Load
(Low RPMs)
P1133 2 Lower Load
(Low RPMs)
P1125 1 Upper Load
(High RPMs)
P1132 2 Upper Load
(High RPMs)
Old 06-27-2016, 04:42 PM   #12
Boxy_02's Avatar
This is what I know from hooking up my scan tool (at idle):
1) Both Pre-Cat O2 Sensors fluctuate up and down.
2) Both Post Cat O2 Sensors steady around 0.735
3) MAF reading 3.5-4.0 g/s
4) Pulled Oil Fill Cap, and idle became very bad and there definitely was vacuum present.
The MAF spec above says 13-15 kg/min, should that be kg/hr?
If I do the conversion it is in the ball park 12.6 - 14.4 kg/hr.
Still have not put in the Techron.
Old 06-28-2016, 05:49 AM   #13
Project Addicted
jcslocum's Avatar
You may need to smoke the engine to find the leak(s). You can make one easy enough or take it to a shop that has a smoke machine.
______
Jon
1966 912, 1976 911
