Old 06-26-2016, 01:48 PM   #11
Topless
Track rat
Topless's Avatar
Agree an intake air leak is most likely. A failed MAF is also possible as the car is running lean. Clogged injectors are possible but unlikely affecting both banks.
TS guide for 2002 model 986:
DME 7.2 (2000-2002 Boxsters)
P-Code Bank RPM Range Reason Look for:
P1128 1 Idle Engine is running very lean and the fuel adaptation has
pegged its rich correction.
Intake/Exhaust system leaks; MAF not performing correctly; fuel
delivery components cannot deliver enough fuel.
P1130 2 Idle Engine is running very lean and the fuel adaptation has
P1126 1 Lower Load
(Low RPMs)
P1133 2 Lower Load
(Low RPMs)
P1125 1 Upper Load
(High RPMs)
P1132 2 Upper Load
(High RPMs)
