-   -   P1128 & P1130 (Again) (http://986forum.com/forums/boxster-general-discussions/62127-p1128-p1130-again.html)
Boxy_02 06-25-2016 02:50 PM
First I did search and found some answers - tried solutions but did not help.
When the car is cold, the engine runs rough for a few minutes then smoothes out.
The p1128 and p1130 codes trigger if the car is in traffic sitting (idle) for an extended period of time.
Car still runs great!
I cleaned the MAF - no difference
I have swapped the MAF - made no difference.
Replaced AOS.
Replaced cracked dip stick tube.
Replaced both pre-cat O2 sensors.
Checked Intake connections - everything is tight.
As per my OBDII Reader, one O2 sensor reads a little higher than the rest.
Any other ideas or suggestions?
jdraupp 06-25-2016 04:17 PM
Which o2 sensor is reading high and is it within range? If not try replacing that sensor (unless already replaced, not clear). You may also try running a bottle of chevron tech Ron through. I did this along with an o2 sensor replacement and my car hasn't popped these codes since.
jcslocum 06-26-2016 03:10 AM
It's not the 02 sensors, they are reading like they should. You have a lean condition caused by false air introduced after the MAF, so not measured by the MAF. The ECU can no longer keep the mixture in range by trimming so throws a code.
1128 and 30 are the idle mixture trim code and not running at speed codes for BOTH sides of the engine. I would concentrate my looking at the center of the plenum for a cracked rubber part of loose clamp. The other thing to change is the fuel pressure regulator on the drivers side of the engine. It's a $45 part and 15 minutes to change.
Chasing these leaks can make you pull your hair out!!!
Boxy_02 06-26-2016 04:45 AM
I was reading that "lean" condition on those codes only apply to 98 - 99 cars? On later cars it indicates a "rich" condition? Can anyone confirm this?
Lapister 06-26-2016 06:37 AM
Ever so slight a vacuum will throw these codes. Check all your hoses including AOS and slip connectors. Mine was the corrugated Aos at TB after 996 conversion.
jdraupp 06-26-2016 06:57 AM
These codes can also come from a dirty or out of spec fuel spray from an injector. The techron can clean them and take care of that. Being that you've taken care of a lot of the primary causes for these codes, try a fuel cleaner.
Boxy_02 06-26-2016 07:56 AM
I will give the fuel cleaner a try. Is Techron what most people here are using?
911monty 06-26-2016 08:09 AM
I use the Lucas fuel system cleaner. It is also MUCH easier to get into the fuel fill flapper valve without spilling.
jdraupp 06-26-2016 08:42 AM
Techron came with the most wide recommendations. Make sure you get the size that treats over 12 gallons.
san rensho 06-26-2016 11:22 AM
Vacuum leak somewhere. Check the MAF values. For the base it should show 13-15 kg/min. If its less ghan that. You have vacuum leak.
Topless 06-26-2016 12:48 PM
Agree an intake air leak is most likely. A failed MAF is also possible as the car is running lean. Clogged injectors are possible but unlikely affecting both banks.
TS guide for 2002 model 986:
DME 7.2 (2000-2002 Boxsters)
P-Code Bank RPM Range Reason Look for:
P1128 1 Idle Engine is running very lean and the fuel adaptation has
pegged its rich correction.
Intake/Exhaust system leaks; MAF not performing correctly; fuel
delivery components cannot deliver enough fuel.
P1130 2 Idle Engine is running very lean and the fuel adaptation has
P1126 1 Lower Load
(Low RPMs)
P1133 2 Lower Load
(Low RPMs)
P1125 1 Upper Load
(High RPMs)
P1132 2 Upper Load
(High RPMs)
Boxy_02 06-27-2016 04:42 PM
This is what I know from hooking up my scan tool (at idle):
1) Both Pre-Cat O2 Sensors fluctuate up and down.
2) Both Post Cat O2 Sensors steady around 0.735
3) MAF reading 3.5-4.0 g/s
4) Pulled Oil Fill Cap, and idle became very bad and there definitely was vacuum present.
The MAF spec above says 13-15 kg/min, should that be kg/hr?
If I do the conversion it is in the ball park 12.6 - 14.4 kg/hr.
Still have not put in the Techron.
jcslocum 06-28-2016 05:49 AM
You may need to smoke the engine to find the leak(s). You can make one easy enough or take it to a shop that has a smoke machine.
