Old 06-14-2016, 02:40 AM   #1
Super Fast Rear Tire Wear
Last October I put a set of Bridgestone Potenza tires on the rear of my 2001 Boxster S. I looked at them last week and discovered they are worn down to the wear bars. The wear is even across each rear tire but I got less than 5,000 miles out of them. I usually get between 8 and 10 thousand miles out of a set of rear tires. No track days, drifting lessons or anything but normal street use. Has anyone else experienced this accelerated wear with these tires?
John
linklaw is offline   Reply With Quote
Old 06-14-2016, 03:38 AM   #2
Retroman1969's Avatar
No doubt Porsches really eat up rear tires, but usually not quite that quickly. Could it be the tires themselves? I've actually read on a couple of other Porsche forums a complaint post or two about someone mounting Bridgestone Potenzas and getting less than 5,000 miles out of them.
Old 06-14-2016, 04:05 AM   #3
Yeast Rancher
Beer's Avatar
I'm having a similar experience with Hankooks. I'm thinking I may need an alignment.
2001 Boxster S
2010 Nissan Xterra S
Always get the S
Beer is offline   Reply With Quote
Old 06-14-2016, 04:56 AM   #4
flete25's Avatar
100% correct ! you need an alignment on rear tires...it happened to me ..my shop told me that basically I was dragging my tires (whatever that means)
flete25 is offline   Reply With Quote
Old 06-14-2016, 07:08 AM   #5
Porsche9's Avatar
Normal is 10k to 15k for the rear tires. I usually get about 12k to 14k. Fronts last twice as long.
An alignment will also make a huge difference in how the car handles.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 06-14-2016, 07:37 AM   #6
Dave S.'s Avatar
I got tired of replacing my tires after a season or season and a half, so I went with Continental Extreme Contact DWS tires. Have been running them for a couple of seasons now (6,000 miles) and they still look almost new. I'm happy with the way they handle, (I don't track my car, but I do enjoy hard acceleration). They have the highest wear rating of any all-season tire I could find.
They look and work great and were recommended by my friend that drives a 993 after he got less than 2000 miles on his previous set of rear tires. I waited to buy them until he had two seasons on his tires and they still looked great. He's on his 5th season on a single set of these tires now.
Check them out if you want better tire life. I don't have a tread depth gage but here is what the rear tire tread looks like after 6k miles:
Dave S.
2003 Boxster S
Old 06-14-2016, 08:08 AM   #7
Xpit77's Avatar
Get an alignment. If you don`t track it get it set to factory.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 06-14-2016, 08:07 AM   #8
JayG's Avatar
John
which Potenza specifically. They make about 20 different versions
Old 06-14-2016, 09:57 AM   #9
steved0x's Avatar
LOL that is fact!
Old 06-14-2016, 10:06 AM   #10
kk2002s's Avatar
Isn't the rear suppose to have a bit of Negative camber (Wear on the inside)?
If it's wearing even, that may indicate alignment is off.
Seal Grey
Old 06-14-2016, 09:38 AM   #11
Did you guys read that article in Panorama last year about the Turbo owner who put something like 700k miles on his turbo with tons of cross-country driving?
He got tired of wearing out rear tires in 10-12k miles since he did a lot of straight line driving and had his alignment shop back off on the amount of camber used in the factory settings. Now he gets 20k miles on a set (if I recall the numbers correctly).
I've considered doing this on my boxster since I live in Houston Texas and it's as flat as a pancake here. No twisty roads to navigate, that's for sure!
Old 08-03-2016, 03:34 PM   #12
It works on a Boxster too. I bought my Boxster with Bridgestones on the car whose rears were not wearing evenly. Aware of the wear issues with Boxsters and having access to a group that set up Porsches for racing and thus knew what settings had what effect, I told them to dial some performance out and set it up for long wear. I replaced the tires with take-offs (PS2s) already mounted on wheels from some well to do guy who wanted bigger flashier wheels. 15k later I replaced those rears due to age, not wear. I know I could have gotten another 5k out of them. The expertise of the person who does the alignment matters greatly.
Old 06-14-2016, 03:54 PM   #13
I hate to say this, but 5K miles for a set of rear tires isn't highly unusual. I say this because I never got more than 5,000 miles from a set of rear tires.
Tips for longer tire life: Accelerate slowly. Select a high UTGQ tire. Accelerate slowly. Have the alignment checked. And drive slowly.
Old 08-03-2016, 10:14 AM   #14
B6T
If you're desperate enough to drive slowly, you could save even more money by selling the Porsche and getting a Corolla.
B6T is offline   Reply With Quote
Old 08-03-2016, 08:02 PM   #15
Sorry, mentioning driving slow several times was a poor attempt at sarcasm.
As for me personally, I can't seem to get more than 500 miles from a set of tires. Slowing down is definitely not an option.
Old 06-14-2016, 05:39 PM   #16
You guys ever try "flipping" your tires to enhance wear life? (inside out)?
I noticed the inside edges of both my fronts and my rears are getting noticeably more worn than the rest of the tread surface, so am contemplating having them all "flipped". I believe they are non-directional, but if they are directional, I can swap them left/right while flipping.
I already set the alignment up to get the minimum of the negative camber specification range on the rear, and maximum on the range on the front, so at least maybe my fronts and rears will wear a bit more evenly now.
I'm not willing to completely sacrifice good cornering performance only for the sake of extending tread life. (And if I got to that point in my rationale, I figure I would reconsider my car selection choice - one of the best handling cars potentially out there - with 8-10" wide rubber available in factory stock wheel/tire configuration(!) - anyway.)
Just curious if anyone here has had success flipping. Thx!
2001 Boxster
Old 06-14-2016, 06:52 PM   #17
Giller's Avatar
Believe they are directional. Looked into flipping my tires to get rid of some feathering - research seemed to suggest because they are directional, water would not channel properly through the tread and lead to potential hydro-planning.
Not sure if that is true, just what I found in my limited search. That being said, I don't drive my Box in the rain....
Old 06-15-2016, 03:59 AM   #18
01101
You are talking about swapping wheels and tires side to side, he is talking about taking the tires off the wheels and swapping them so the insides are now on the outside, then swapping side to side. Direction of tire rotation will stay the same.
I have done this once on my old benz. Rears were 345/35/15 and the insides were toast. It got me a couple hundred miles. You definitely won't double the use of the tire.
alm001 is offline   Reply With Quote
Old 06-15-2016, 10:59 AM   #19
Known Gearhead
imon_2nd's Avatar
One more factor in rapid tire wear: worn suspension parts or wheel bearings. I've had this issue in several sports cars over the years. The increase in vibration can be too subtle and increases so gradually that you don't notice. Sometimes, the tire wears evenly across the tread, sometimes not.
2004 Boxster S
imon_2nd is offline   Reply With Quote
Old 06-14-2016, 05:40 PM   #20
First HPDE coming up, question on tires
Moved my post to a new thread which was my original intent. Sorry!
